Author Topic: hiscore diff (with no nag/white box removal)  (Read 919982 times)
MKChamp
  • Last login:December 24, 2025, 01:30:45 pm
  • Stil around.
Re: hiscore diff (with no nag/white box removal)
« Reply #520 on: October 18, 2010, 11:05:18 am »
LOL...it's been out!
You don't see it with the following at the bottom: Last Edit: October 14, 2010, 11:59:23 AM by MKChamp ?
WhereEaglesDare
    • My HomePage
« Reply #521 on: October 18, 2010, 02:26:29 pm »
 :dunno Ahh I was looking at the end of the thread for the post...   :banghead:  Sorry
tkeahi
  • Last login:November 03, 2021, 05:39:33 am
« Reply #522 on: November 04, 2010, 07:50:27 pm »
I used the 140 diff file and compiled 140 but still get the "Initializing" and "Loading" white boxes. All the other nag screens get skipped.
-Disregard, I see the patch got updated. I'll download it and try again.
« Last Edit: November 04, 2010, 07:57:23 pm by tkeahi »
MKChamp
  • Stil around.
« Reply #523 on: November 05, 2010, 01:19:10 am »
yea...I haven't been testing...at all...really...and another mamer told me that a screen was showing up, so I re-uploaded a new 140 patch. Sorry to waste your time...let me know if anything else seems lacking...
abelenki
  • Last login:January 04, 2026, 10:56:26 pm
    • MAME Stuff
« Reply #524 on: November 08, 2010, 10:27:17 am »
MKChamp, just wanted to let you know that your patch works brilliantly with MESS/MESSUI.
i just tried to compile MESS/MESSUI 0.140 (first time in my life). i applied hi_140.diff to MAME/MESS source tree, then compiled, and MESSUI doesn't have nag screens anymore.
awesome!! thanks a lot!!
p.s.: hi_140.diff doesn't apply to MAME 0.140u1 source tree, so i'm patiently waiting for hi_140u1.diff. ;)
MAME Stuff | MAME favorites | Bubble Bobble Series chart / wiki | PC configuration
MKChamp
  • Stil around.
« Reply #525 on: November 08, 2010, 11:37:01 pm »
Wait no more. 140u1 is up and ready. There was quit a bit changed from 140 to 140u1...so let me know if everything still works!
...and thanks for hosting the files!
abelenki
    • MAME Stuff
« Reply #526 on: November 09, 2010, 01:06:13 am »
many thanks!! i will check it out when i'm at home.
no problem. it's a pleasure for me to host such a great project.
wweumina
  • Last login:August 30, 2022, 04:56:31 am
« Reply #527 on: November 13, 2010, 08:54:11 am »
There does seem to be a problem with the 140u1 hi score diff.  I've compiled 140u1 and it works fine, but when adding the hi patch I now can't play Donkey Kong.  I get garbage over the high score tables and it seems to have deleted my high scores for the game.  Not game to try any other games after losing the DK high scores.
MKChamp
  • Stil around.
« Reply #528 on: November 13, 2010, 12:31:04 pm »
I actually 'use' dkong when testing and it works fine for me. Try a clean compile.
WhereEaglesDare
    • My HomePage
« Reply #529 on: November 13, 2010, 10:38:22 pm »
I just tried it and it works fine for me.  i even made a new hi score on mine and it stayed.
BTW I really like the new font they are using on the UI.
wweumina
« Reply #530 on: November 14, 2010, 12:52:25 am »
Yeah, sorry it was a strange one.  I deleted the dkong.hi file and it worked again.  I had to dig out my hex editor to put my scores back in but it's ok now.
« Reply #531 on: November 26, 2010, 12:49:58 pm »
I just did my own compile for the first time (yay), and I too had the same issue with Donkey Kong (and only DK). Deleting the hi file makes it work, but then it happens over again. Wierd.
B2K24
  • Last login:June 10, 2025, 10:17:56 am
« Reply #532 on: November 27, 2010, 02:48:13 am »
Thank you very much MKChamp, Everything working great here. When u2 is released I will be happy to test anything you post.
Thank you so much for your time and work :)
B2K24
« Reply #533 on: December 09, 2010, 11:09:39 am »
Many Thanks for having 140u2.diff posted so soon after the source release. Your work is very much appreciated :)
MKChamp
  • Stil around.
« Reply #534 on: December 09, 2010, 03:40:24 pm »
No need to thank me, I do it for myself  ;)
But you're welcome!
bitbytebit
« Reply #535 on: December 18, 2010, 06:36:31 am »
This patch when applied after the newest 140u2 hiscore patch will fix a bug that crept in which the machine memory was being freed before the hiscore callback read the hiscore to the games .hi file.  This probably is why some people had some games work and others not, or experienced random working and not.  I think in Windows the memory was still there, just technically freed but it was accessing memory that was freed to the operating system already (just lucky sometimes).  In Linux this turned out to always fail, at least on certain games, but not all of them.  Strange but this definitely is a bug that this patch fixes...
diff --git a/src/emu/machine.c b/src/emu/machine.c
index 6726451..dadcf47 100644
--- a/src/emu/machine.c
+++ b/src/emu/machine.c
@@ -332,10 +332,6 @@ void running_machine::start()
        crosshair_init(this);
        sound_init(this);
-  //MKCHAMP - INITIALIZING THE HISCORE ENGINE
-       if (!options_get_bool(&m_options, OPTION_DISABLE_HISCORE_PATCH))
-               hiscore_init(this);
        // initialize the debugger
        if ((debug_flags & DEBUG_FLAG_ENABLED) != 0)
                debugger_init(this);
@@ -361,6 +357,10 @@ void running_machine::start()
        // set up the cheat engine
        m_cheat = auto_alloc(this, cheat_manager(*this));
+       //MKCHAMP - INITIALIZING THE HISCORE ENGINE
+       if (!options_get_bool(&m_options, OPTION_DISABLE_HISCORE_PATCH))
+               hiscore_init(this);
        // disallow save state registrations starting here
        state_save_allow_registration(this, false);
Here's the way I tracked it down, shows the backtrace of it trying to access the machine when it was already technically freed...
#0  0x000000000202703d in astring_c (str=0x80) at src/lib/util/astring.c:499
No locals.
#1  0x000000000040f280 in astring::operator char const* (this=0x80) at src/lib/util/astring.h:344
No locals.
#2  0x000000000040f69e in device_config::tag (this=0x0) at src/emu/devintrf.h:287
No locals.
#3  0x000000000040f6e6 in device_t::tag (this=0x6de6d90) at src/emu/devintrf.h:441
No locals.
#4  0x0000000000430dea in device_memory (device=0x6de6d90) at src/emu/dimemory.h:192
        intf = 0x0
#5  0x0000000000430e6a in device_get_space (device=0x6de6d90, spacenum=0) at src/emu/dimemory.h:204
No locals.
#6  0x0000000001e69af0 in copy_from_memory (machine=0x6d5c1e0, cpu=0, addr=20104, dest=0x6de6ff0 "\260\371B\a", num_bytes=4) at src/emu/hiscore.c:89
        i = 0
        targetspace = 0x6de6ff0
#7  0x0000000001e6a181 in hiscore_save (machine=0x6d5c1e0) at src/emu/hiscore.c:280
        data = 0x6de6ff0 "\260\371B\a"
        mem_range = 0x73b0f80
        filerr = FILERR_NONE
        f = 0x6d5d5c0
        fname = 0x6d58940
#8  0x0000000001e6a25d in hiscore_close (machine=...) at src/emu/hiscore.c:312
No locals.
#9  0x0000000001b75176 in running_machine::call_notifiers (this=0x6d5c1e0, which=MACHINE_NOTIFY_EXIT) at src/emu/machine.c:778
        cb = 0x73b0f60
#10 0x0000000001b74523 in running_machine::run (this=0x6d5c1e0, firstrun=true) at src/emu/machine.c:453
        error = 0
#11 0x0000000001b70cac in mame_execute (osd=..., options=0x6d38b50) at src/emu/mame.c:203
        gamename = {<_astring_base> = {text = 0x7fffffffe06c "pacman", alloclen = 52,
            smallbuf = "pacman\000\377\377\177\000\000.\257\003\002\000\000\000\000\264\032|\003\000\000\000\000`\227\324\006\000\000\000\000\255+|\003\000\000\000\000P\213\323\006\000\000\000"}, <No data fields>}
        driver = 0x2d87d40
        config = 0x6d6c010
        machine = 0x6d5c1e0
        firstgame = false
        firstrun = true
        exit_pending = false
        error = 0
#12 0x0000000001b0a3e4 in cli_execute (argc=2, argv=0x7fffffffe4a8, osd=..., osd_options=0x364ccc0) at src/emu/clifront.c:175
        gamename_option = 0x6d28f5c "pacman"
        driver = 0x2d87d40
        exename = {<_astring_base> = {text = 0x7fffffffe1dc "mame64", alloclen = 52,
            smallbuf = "mame64\000\004", '\000' <repeats 36 times>"\202, \303\336\367\377\177\000"}, <No data fields>}
        options = 0x6d38b50
        result = -1
        gamename = {<_astring_base> = {text = 0x7fffffffe21c "pacman", alloclen = 52,
            smallbuf = "pacman\000\000\000\000\000\000\350\213\264\367\377\177", '\000' <repeats 18 times>"\300, \343\377\377\377\177\000\000\340\243@\000\000\000\000"}, <No data fields>}
#13 0x00000000013183f6 in main (argc=2, argv=0x7fffffffe4a8) at src/osd/sdl/sdlmain.c:328
        osd = {<osd_interface> = {_vptr.osd_interface = 0x364d850, m_machine = 0x6d5c1e0}, <No data fields>}
        res = 0
This occured at least on pacman and tempest, donkey kong games seemed to somehow still work, guessing it's in how the machine for each game handled freeing the resources and probably some luck of memory being there even when already freed from mames ownership.
MKChamp
  • Stil around.
« Reply #536 on: December 19, 2010, 04:11:24 am »
Thanks for the info. I re-uploaded 140u2 patch with the change...and they'll all have the move going forward.
Thanks again for the feedback!
Creeper
  • Last login:January 10, 2012, 11:55:07 pm
    • The Naked Robber
« Reply #537 on: December 26, 2010, 04:00:55 am »
Ok, I'm new to compiling so don't judge me. Here's what I'm doing:
I've taken a fresh Mame139 source and I'm trying to compile using Mr. Do's instructions. I took the hi_139.diff that is supplied in this thread and I put it in the source directory. I patched mame with the diff and it seemed to work fine. I used the makemame.bat to start the compile and it seemed to be working although it took under 1 minute which is suspicious, but the file size was still 40mb+ and looked healthy. I then took the new EXE and copied it into my master mame139 directory I've been using. I also added the hiscore.dat and hi directory. When running the exe, nothing happens, a cmd flashes but nothing else.
The odd thing is that when I compile without using the hi_139.diff, the compile is completely normal. Takes about 10-15 minutes and it runs perfectly in the master directory.
Did I do something wrong with the patching? I changed the patchmame.bat to:
set path=C:\MinGW\mingw64-w32\bin
patch -p0 -E <hi_139.diff
The set path is correct and as I said it seemed to work.
jahilton2002
  • Last login:January 17, 2026, 05:34:53 pm
« Reply #538 on: December 26, 2010, 07:35:12 am »
is there a u3 release for this thx  :angel:
WhereEaglesDare
    • My HomePage
« Reply #539 on: December 26, 2010, 09:45:54 am »
You want to try HeadKaze's Compiler.  It's a piece of cake and does the commands for you.
http://www.headsoft.com.au/index.php?category=mame&page=mc64
jahilton2002
« Reply #540 on: December 26, 2010, 09:52:24 am »
your a star  :notworthy: thx mate
Creeper
    • The Naked Robber
« Reply #541 on: December 26, 2010, 07:36:35 pm »
Nice, yea Mame compiler worked much better but I still have a few questions and I'm not sure if this is for MKchamp or Headkaze.
I patched my Mame using the hi_139.diff and it worked fine, I compiled using Mame compiler and it also worked fine. I took the new EXE and dumped it into my Mame folder and started playing Donkey Kong Jr. I played for a bit and got a decent score, entered my name and what not and then hit reset to see if the score kept. It didn't. I exited to windows, and check the HI directory to see if there was anything and sure enough there was a dkongjr.hi file in there. What am I missing? It seems like its working but the game won't recognize it.
Also when I go to pause any game (mapped to keyboard F10) Mame crashes. Using the regular Mame.exe and it pauses fine.
Any help?
WhereEaglesDare
    • My HomePage
« Reply #542 on: December 26, 2010, 07:57:39 pm »
By reset do you mean you hit the MAME Reset key or escaped out and went back in..  If you reset the game (I think it is F3) it wipes it clean.  Get a score and hit escape and go back in and it will save it.
Also, Ive never had an issue with pause but I have had MAME crash on sometimes lately after exiting some games, like BioMechanical Toy, it will crash and lock up my Front End and I have to power down the cabinet to get it back up.
« Last Edit: December 26, 2010, 08:00:24 pm by WhereEaglesDare »
Creeper
    • The Naked Robber
« Reply #543 on: December 26, 2010, 08:15:15 pm »
Yea, I've been using the soft reset. I just tried exiting and going back in, you are right it is working. Is there anyway to soft reset without losing your high scores?
Thanks for your help
WhereEaglesDare
    • My HomePage
« Reply #544 on: December 26, 2010, 08:17:43 pm »
Hmm I dunno.  MKChamp would know if there is.  Its probably a diff you can add in the mix to change the softreset.  Id like to know too, Id like to use reset but just dont and never though to ask about it.
Creeper
    • The Naked Robber
« Reply #545 on: December 26, 2010, 08:30:19 pm »
After further research it would appear that anything to do with Mame admin buttons is freezing Mame for me. This includes just hitting tab on the keyboard to bring up the Mame menu.  :-\
WhereEaglesDare
    • My HomePage
« Reply #546 on: December 26, 2010, 10:18:23 pm »
So if you hit TAB the thing locks up, how do you get out of MAME to fix it?  Do you have to restart the PC?  Do you have another PC you can try the MAME on to see if it is isolated to your PC?  What are the Specs of the MAME PC?  Are you using a front end?  What version MAME are you using?  140u2 hi?
Creeper
    • The Naked Robber
« Reply #547 on: December 27, 2010, 12:18:51 am »
When Mame crashes I get a windows error saying mame has stopped working, then it goes straight back to Maximus Arcade.
I just took a completely fresh Mame139 with the compiled mame.exe and nothing but a donkey kong rom. I ran it and it works perfect. I copied my old mame.ini file into the mame directory and tried to run it again but it instantly crashes. So I create a brand new mame.ini file and try that, works perfect. Long story short as soon as I enable direct draw for my ArcadeVga and d9800 Mame won't run, but it works perfect with the old copy of Mame.
Any thoughts?
kaptainsteve
  • Last login:November 22, 2025, 09:12:21 pm
    • Swamp-Ass
« Reply #548 on: January 01, 2011, 06:00:39 pm »
Hello,
Can somebody please help?
What do you do when compiling mame and you get this;
 "mingw32-make' is not recognized as an internal or external command, operable program or batch file.
Any suggestions will be appreciated.
Thanks.
Steve
« Last Edit: January 01, 2011, 07:00:12 pm by kaptainsteve »
Bonechip
  • Last login:June 10, 2012, 12:24:52 am
    • "The Arcade Machine"
« Reply #549 on: January 01, 2011, 06:55:46 pm »
Thank you MKChamp for keeping up with the Diff's.
abelenki
    • MAME Stuff
« Reply #550 on: January 01, 2011, 09:04:28 pm »
it means, your MingW/bin folder is not set in your system paths. before compiling, make a .bat file with contents like this for patching:
set path=c:\MinGW\bin
patch -p0 -E < hi_141.diff
and for compiling:
make all
otherwise, read compiling guides.
nintendoid
  • Last login:January 21, 2026, 03:37:38 pm
    • Nintendoid
« Reply #551 on: January 09, 2011, 12:10:31 pm »
hi I assume everyone is trying this on mame32... do you know if this works for just mame .141??? I too need the Donkey Kong save  :cry:
If someone has got this working please let me know...  :applaud:
WhereEaglesDare
    • My HomePage
« Reply #552 on: January 09, 2011, 12:46:03 pm »
Works great with regular old MAME. Thats what I use.
abelenki
    • MAME Stuff
« Reply #553 on: January 09, 2011, 12:57:21 pm »
hiscore diff works with all MAME and MESS versions for which it's available - see the first page. namely - 0.108 to 0.141.
wonderalex
  • Last login:January 19, 2025, 07:48:29 pm
« Reply #554 on: January 10, 2011, 11:58:10 pm »
Ok - I give up.
I've been at this for 2 hours and I'm not getting anywhere.
I'm trying to re-compile MAME 135b (that's the MAME library I have) with the hiscore diff for my bro (who wants his hi scores - even if I cream him everytime I visit his place   8) ) .
I've tried Mr.Do's tutorial - the diff installs, but the compiling always ends in a few minutes with an error. When I try it again - it ends in seconds with an error.  I'd show you the code but I can't for some reason.
MAMECompiler64 1.17 and 1.18 won't even launch.
Help?
WonderAlex
WhereEaglesDare
    • My HomePage
« Reply #555 on: January 11, 2011, 12:11:53 am »
I dunno, why not try to get the latest sets, 140 or 141, 140u1 has the hacked Donkey Kong 2 on it...
MKChamp
  • Stil around.
« Reply #556 on: January 11, 2011, 12:14:18 am »
I believe the b means binary...or exe. You need the s or source to compile your own. Read and get headkaze's mame compiler. Everyone says it makes it as easy as turning your computer on.
Edit: I might have misread. I thought u were saying you tried to compile starting with the binary. At any rate, read headkazes thread thoroughly.
« Last Edit: January 11, 2011, 12:17:53 am by MKChamp »
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #557 on: January 11, 2011, 12:18:47 am »
Agreed  used headkaze's compiler. A chimp could use it, it's that easy
wonderalex
« Reply #558 on: January 11, 2011, 09:46:40 am »
Yeah - I know 135s is the source (I'm not THAT daft  :laugh: ), and I've followed the instructions yet I still get an error. I guess I could use the latest build and continue to use the 135 library until I get it updated - I'll think about it.
The real weird thing is Headkaze's compiler will not work. It doesn't even start.
I'm going to try it again with both flavours of MAME on my workstation (with XP) at the office over lunch.
I'll report back.
WonderAlex
Donkbaca
« Reply #559 on: January 11, 2011, 11:45:53 am »
You have to completely delete the mame program, then re-download the source and diffs and start from scratch.  Otherwise it won't work.  You don't have delete the roms or the samples or that stuff, but you need to delete the exe and the other stuff in the root file, and start from scratch to use the compiler. Otherwise the compiler gets confused.
