Author Topic: Xbox 360 Controller Hack Tutorial -- Wireless Hack Now Available!!!  (Read 560341 times)
  • Last login:February 28, 2026, 04:55:22 pm
Now, before I begin; a little disclaimer:  This is a difficult hack to do.  I am not responsible if you fry your controller, Xbox 360, or whatever else.  That being said, I will hack your controller for you, for a fee.    :D
Step 1:  Remove the housing.  There are 6 screws visible on the back of the controller, plus one under the serial number sticker.  Discard the buttons, pull off the analog sticks by pulling straight up, and disconnect the vibration motors.
Re: Xbox 360 Controller Hack Tutorial
« Reply #1 on: March 08, 2007, 08:09:58 am »
Step 2:  Remove the white triggers from their black plastic housing.  This requires some effort (be careful!) but is neccessary.  Once you have the triggers removed, you will need to cut away some of the black plastic to get at the solder points underneath.  You will need these for the LB and RB buttons.  I have circled the solder points in yellow, they are the same for the other button as well.
« Reply #2 on: March 08, 2007, 08:11:41 am »
Step 3:  Get a variable speed Dremel and a wire wheel, if you don't already have one.  They will make your life a whole lot easier.
« Reply #3 on: March 08, 2007, 08:16:03 am »
Step 4: Preparing A, B, X, Y, Start, Back, and Xbox buttons.  Now, as far as I can tell, there is no common ground on this controller, so you will need two wires per button.  Take the Dremel with wire wheel, set it to a low speed, and apply a gentle pressure to the black semi-circle for each button.  This takes some practice to get the needed pressure and angle of the wire wheel right.  Just be careful, and don't bare down too hard.  Once you can see a good strip of copper where the black used to be, stop.  After you finish the semi-circles, clean the area with alcohol and a Q-tip.
« Reply #4 on: March 08, 2007, 08:17:04 am »
These tools are handy...  free up your hands for more precise control of the Dremel and a soldering iron later.
« Reply #5 on: March 08, 2007, 08:21:58 am »
Step 5:  Preparing the directions.  This is the hard part.  As you can see in the picture, the direction switches are designed differently.  You can't just remove the black to get to copper underneath.  However, if you look closer, there are two black dots on either side of each direction.  These will be your solder points.  There is copper undeath each little black dot, you can see I have circled them in yellow.  You have to be careful at this stage so you do not wreck other parts of the controller.  You can remove the black substance using the Dremel and wire wheel, just as before.  Once that's done, you will be left with 8 tiny solder points.
« Reply #6 on: March 08, 2007, 08:23:22 am »
I'll be finishing this tutorial up later today, I have to wait for Radio Shack to open, I need to get a new (sharp) soldering iron tip.
johnperkins21
  • Last login:December 07, 2019, 07:02:34 pm
« Reply #7 on: March 08, 2007, 10:52:12 am »
Those tiny solder points for the directionals are exactly why I paid HarumaN to do this hack for me. I've already ruined one $30 controller, no need to ruin another one when there are professionals available.
This is a good write up so far, looking forward to seeing the final results.  ;D
Bob Dole likes cheese.
« Reply #8 on: March 08, 2007, 01:10:34 pm »
Step 6:  Now that all the points are prepared, apply some solder to each point.  You don't need a lot, and you need to make sure that you don't create any shorts.  Next, start wiring...  I find it easier if I "pre-tin" each wire before soldering it.  I apply some solder directly to the wire, and then solder the wire to the solder point on the PCB.
« Reply #9 on: March 08, 2007, 01:12:41 pm »
Step 7: Apply hot glue.  Hot glue is your friend!  It will help the wire stick, and prevent the wire from coming up and potentially pulling traces.  Repeat now for each set of wires...
« Reply #10 on: March 08, 2007, 01:15:37 pm »
Finished!  I like to use terminal strips, it prevents wire fatigue to the hack.  Also, it makes wiring easier, IMHO.
« Reply #11 on: March 08, 2007, 01:16:48 pm »
Last but not least, the pin-out:
johnperkins21
« Reply #12 on: March 08, 2007, 01:19:39 pm »
This is exactly what I did wrong. I pre-tinned the iron and wire, but never thought of just putting a dab of solder on the pcb to connect to. I think my tip was a little big for the project as well. Another case of making things tougher by not having the right tools for the job.
This was a great little tutorial, and I'll definitely use some of these tips if I ever try it again for myself.
« Reply #13 on: March 08, 2007, 04:53:10 pm »
Yeah, my method takes some time to do... but I've never had anyone return a hacked controller.  :)
orntar
  • Last login:November 18, 2010, 03:35:04 pm
  • boo!
    • neogeo.orntar
« Reply #14 on: March 08, 2007, 09:36:26 pm »
does it really need discreet commons for every button?
can at least some of the buttons be paired down, so there aren't so many connections?
- just say no to capitol letters -
« Reply #15 on: March 09, 2007, 06:18:56 am »
There may be.  I just did a visual inspection, I didn't do a thorough check with a multi-meter.  I decided to save myself the hassle and just do two wires per button/direction.  I know for a fact that there is not one single common ground (which would have been nice, but oh well).
ppilot
  • Last login:January 06, 2020, 01:33:27 pm
« Reply #16 on: March 09, 2007, 06:58:59 am »
Wow, that was a great writeup!  Except that I have no idea what you accomplished.
« Reply #17 on: March 09, 2007, 09:16:50 am »
Well, you know Xbox 360 has the whole Xbox Live Arcade thing.  You can download classic arcade games and play offline or online with/against other people on Xbox Live.  I've been playing SFII online against people, and the Xbox 360 controller sux.  So why not build your own arcade style controls to play Xbox Live Arcade games with?
That's what this hack is for.   :)
somunny
  • Is it hot in here?
« Reply #18 on: March 09, 2007, 10:03:55 am »
Nice job, HarumaN!   Aren't you in AZ now?
« Reply #19 on: March 09, 2007, 11:30:49 am »
Nope not in AZ yet, I'll be moving first part of June, my new job starts June 14th.  I can't wait!
somunny
« Reply #20 on: March 09, 2007, 04:00:37 pm »
What kind of stick are you using for SFII on XBLA?  Also, how does the stick work with four way XBLA games like Ms. Pac Man and Dig Dug?
« Reply #21 on: March 09, 2007, 04:30:28 pm »
I haven't done one for myself yet, but when I do, I'll probably use a Happ Competition stick (for SFII).
johnperkins21
« Reply #22 on: March 09, 2007, 04:33:52 pm »
I'll be using a Happ Competition. I'll let you know how it works with 4-ways once I get it put together, but it's almost 100% for SFII and C:SotN. Pac Man and Dig Dug will be played on my cabinet using either an Ultimate 360 or Randy's new 49-way.
« Reply #23 on: March 13, 2007, 06:16:46 am »
So, would any people be interested in these?
somunny
« Reply #24 on: March 13, 2007, 11:49:59 am »
Yes.  Do you have time for one with the big move coming up?
« Reply #25 on: March 13, 2007, 01:28:49 pm »
Yeah I have some time. :)
albert_c
  • Last login:April 06, 2010, 03:57:07 pm
« Reply #26 on: March 15, 2007, 05:02:07 pm »
Thanks for posting this.   :cheers: No common ground is a pain in the ass though.
« Reply #27 on: March 16, 2007, 06:07:38 am »
Yeah no kidding...   :o
bignose
  • Last login:August 23, 2007, 01:35:42 pm
« Reply #28 on: March 20, 2007, 05:38:57 pm »
Thanks for the fantastic tutorial! With the arrival of Virtua Fighter 5 on the xbox I've been getting interested in building a stick, how much would you charge for the board?
« Reply #29 on: March 20, 2007, 08:24:36 pm »
$35 for the wired hack plus $5 shipping to the US.  Also, to save time and shipping costs on your end, I could pick up a new wired controller, and for that I would charge actual cost (not sure how much that is at the moment.)  Let me know!
somunny
« Reply #30 on: March 24, 2007, 01:46:41 pm »
Just got my controller back from HarumaN.  He does a great job!
Thanks, H!  :cheers:
MameMaster!
  • Engage number one!
    • Mame Invaders!
« Reply #31 on: April 05, 2007, 09:52:22 am »
Same here....thanks for a GREAT job!...way better than I could have done any day...worth every penny.
Thanks man!  :cheers:
« Reply #32 on: April 05, 2007, 09:58:15 am »
Hey, thanks for the feedback guys.  :)
In case anyone was interested, total cost (including a wired controller to sacrifice for the hack) is $80 shipped to the US.  Other countries, contact me for shipping.  I take PayPal, funded however you need.
Thanks for looking!
« Last Edit: November 15, 2007, 09:34:35 am by HarumaN »
Donkey_Kong
    • CNC Machines
« Reply #33 on: April 24, 2007, 12:21:00 pm »
Has anyone got anything done with there hacked 360 controllers yet?
If so  :pics
« Reply #34 on: April 24, 2007, 01:20:52 pm »
If so  :pics
Yeah, I'd like to see some shots of them in action.   :applaud:
MameMaster!
    • Mame Invaders!
« Reply #35 on: April 26, 2007, 03:58:44 pm »
I have the housing built....the stick attached .....I just haven't wired it to the hack......I've been getting home really late since I got it from you.
I'll be sure to post photos within a week or so..... :applaud:
bignose
« Reply #36 on: April 27, 2007, 01:54:38 am »
Here's a pic of my xbox 360 stick. Thanks for the helpfull tutorial HarumaN!
mwatson
  • Last login:July 03, 2007, 07:28:59 pm
« Reply #37 on: April 27, 2007, 03:28:11 am »
Sweet looking controller!
I'm waiting for a dremel to appear in my hands to start mine - though I'm going the more shameful route with it, 360 hard dance pad.
« Reply #38 on: April 27, 2007, 05:52:56 am »
You used my tutorial, and made that stick?  Sweet!!!   :cheers:
thennomeking
  • Last login:August 14, 2014, 03:12:31 pm
  • YIPYIPYIPYIP
« Reply #39 on: April 27, 2007, 07:51:09 am »
Only 70 and I can take advantage of a real stick in new shumps?  Id blow $80 on the two controllers I would break attempting this...
We will have to talk in the future.
