Author Topic: Vertical lines on K7000 and K7000A  (Read 3458 times)
darko
  • Last login:June 27, 2008, 01:29:08 pm
« on: March 02, 2007, 06:35:48 am »
I have WG K7000 chassis, I can see  verticall dark lines on the left side of the monitor, shown on the picture, I change all caps, but problem stays.
 :banghead:  ???
darko
Re: Vertical lines on K7000 and K7000A
« Reply #1 on: March 02, 2007, 06:37:56 am »
This is picture :D
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #2 on: March 02, 2007, 08:10:48 am »
You sure you changed C57 too?
darko
« Reply #3 on: March 02, 2007, 09:03:54 am »
I change C56, C57, C50,C48,C40, C45,C46,C42 but lines are still here  :'(
JoeB
  • Last login:February 12, 2026, 11:59:45 am
  • NES Fanatic
« Reply #4 on: March 02, 2007, 01:28:27 pm »
You either have a magnetic source on the left of the tube, or the caps you used were bad.
grantspain
« Reply #5 on: March 02, 2007, 05:24:37 pm »
you changed every single electrolitic on the entire chassis including the neck card?
darko
« Reply #6 on: March 08, 2007, 07:51:04 am »
No, but I change the electrolitic capacitor on the neck card. But lines are still here.
Ken Layton
  • Guru
  • Technician
« Reply #7 on: March 08, 2007, 10:10:10 am »
There are 17 electrolytic capacitors you need to replace on this monitor.
grantspain
« Reply #8 on: March 08, 2007, 03:38:43 pm »
you need to change all the caps in the power supply circuit,i have had the same fault on hantarex polo's and you cannot narrow it down to one cap,you have to change all
Ken Layton
  • Guru
  • Technician
« Reply #9 on: March 11, 2007, 12:47:32 am »
You also need to change these:
C10    33 uf @ 25 volts
C11    22 uf @ 25 volts
C12    1 uf @ 50 volts
C13    22 uf @ 25 volts
C18    1 uf @ 50 volts
C20    10 uf @ 50 volts
C21    10 uf @ 50 volts
C22    1 uf @ 50 volts
C23    47 uf @ 25 volts
