Author Topic: help: I adjusted Dips in Galaga and now screen permanently flipped  (Read 1448 times)
QuixoteQuest
  • Last login:October 18, 2010, 07:24:11 pm
I've run into something I've not encountered before in MAME. I went into Dipswitches to add lives to Galaga. I reset the game and after it ran the reboot of the roms the screen is now flipped upside down. It says "rom ok" on the screen but if I insert coins the game doesn't play anymore. It's not like it will even run upside-down. When I set the lives back to 3 and reset it stayed the same. Changing the rotate options in Video Options doen't help either.
Is this a common problem with this game or is there something I've accidentally switched on? Do I just need to track down a config or setup file and trash and restart the game?
loadman
  • Last login:Yesterday at 07:18:10 pm
    • MaLa
Re: help: I adjusted Dips in Galaga and now screen permanently flipped
« Reply #1 on: March 01, 2007, 05:16:54 am »
Yeah
I would just delete the config file for galaga and start again
QuixoteQuest
« Reply #2 on: March 02, 2007, 12:41:45 pm »
I deleted the cfg files for all the Galagas and it didn't make a difference at all for my Namco license version of Galaga. I switched to one of the two Midway license versions and they are working fine. Because the behaviour was so wierd to have the Namco rom do that when I changed the Dips I wish I could troubleshoot it. But if I don't ever find a solution I still can enjoy the game via the other romsets. Oh well.
ahofle
    • Arcade Ambience Project
« Reply #3 on: March 02, 2007, 12:53:56 pm »
Did you delete the nvram files?  AFAIK the cfg files are for controller settings.
Havok
« Reply #4 on: March 05, 2007, 07:51:47 am »
Just flip your screen upside down...
