Author Topic: Bezels screw up mame.  (Read 2281 times)
N8
  • Last login:February 06, 2026, 10:24:38 pm
  • Gimme A Chance To Do A Hip Hop Dance
« on: March 01, 2007, 12:38:14 am »
Whenever I load a game that has a bezel such as pac man, galaga, popeye, etc they never seem to fit on screen correctly.  Popeye is the worst because it doesn't fit on the screen at all and I need to scroll to the center to play.  Is there a quick fix for this?  I am using an Old version of mame (not sure the version num).  and running maximus arcade.  If need be I could just delete the bezel folder if that will fix it.
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
Re: Bezels screw up mame.
« Reply #1 on: March 01, 2007, 01:03:58 pm »
Newer versions of Mame allow you to crop or remove the bezel for games directly from the tab menu.
My Websites
N8
« Reply #2 on: March 01, 2007, 01:07:18 pm »
The bezel wasn't that big of a deal for me so I just deleted the atwork folder.   But popeye is still screwed up.  Is there a way to set all mame games to fit on screen or would I have to change each games config?
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: March 01, 2007, 01:14:58 pm »
Versions newer than 107 allow you to crop the bezel to the screen.
mame.exe -ver
at the command prompt.
PC monitor?  If so, try setting a fixed resolution like:
Newer MAME try these settings in your mame.ini file (mame -cc from the command prompt if you don't have a mame.ini)
# VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                1
prescale                  1
For an older mame, look for options like
maximize   1
hwstretch  1
keepaspect 1
resolution  640
etc.
ahofle
    • Arcade Ambience Project
« Reply #4 on: March 01, 2007, 01:17:30 pm »
You could also just turn off the bezels in MAME for all games.  Look in the MAME documentation for the parameter to do that.
EDIT: Oops you guys type fast.
N8
« Reply #5 on: March 01, 2007, 01:29:22 pm »
I am using mame 0.102.  I'm going to try and edit my mame.ini.  I am also running on a 29 inch tv.
Circo
    • EmuMovies
« Reply #6 on: March 01, 2007, 02:07:02 pm »
I think that it is version 107 and newer that really handle the artwork aspect well.
My Websites
N8
« Reply #7 on: March 01, 2007, 03:23:13 pm »
I ended up switching keepaspect to 0 and now all works perfectly.  Every game stays on screen perfectly.
