February 05, 2026, 05:20:26 pm
FYI: Hilti makes stellar drills for concrete! I used to use a big Hilti to make 2-1/2" holes through concrete pads. That drill took a beating and always came back for more.
Is an impact driver a hammer drill?EDIT: duh, guess not, the hammer drill is at the bottom.
Lowe's has a deal now through June 17th where if you buy the Black & Decker "Firestorm" starter kit (basically the drill and battery and a case) you get a free power tool. The "Firestorm" Single Source are tools with an interchangeable battery. It's $50 for the drill, then you get to choose a free tool.
An impact driver, on the other hand, pounds in the axis of rotation. Which is to say that it pounds in the same direction the driver is turning.
Understood. What would you use that for?
Bosch 14.4 Volt Impact Driver: $131.82 shipped. I keep trying to tell myself I don't need an impact driver....Keyword: "trying".
I don't know what a good price for this is but I have met several people who own and love this Impact Driver. I think I'm going to pick one up myself one of these days.
Though the Bosch PS-20 isn't an impact drill, I would recommend it for anybody looking to get a regular drill/driver.
Anyone who purchases the PS20 to use as a drill will probably be deeply disappointed... Because of the "Clic-Change" bit holder, you'll have to have hex-shank drill bits which aren't terribly common.
For an impact driver, I recommend one of these:Sears Impact Driver
Dedicating a $100 power tool to impact driving is just retarded for a home diy'er. One of these things though can be a lifesaver when working on old cars. I've put mine to use on a few occasions with stubborn screws/bolts. Plus you get the added benefit of taking your frustration out on a stubborn part in a constructive way.
Lowe's Ad
for anyone who wants an inexpensive router table(w/router)...! Craftsman 2 hp Router and Router Table Combowas $120...now $60...
Quote from: fixedpigs on June 10, 2007, 10:37:37 pmfor anyone who wants an inexpensive router table(w/router)...! Craftsman 2 hp Router and Router Table Combowas $120...now $60... Your link is dead. Here ya go: Router Combo LinkAnyone have experience with this set or and opinion at least? I have been wanting even a cheap router table, but even one like this is always $100 or more. I am considering asking for this for father's day.
Why use tinyurl when you can use the [url] tags? They're there for a reason.
There is a [url] button in the toolbar, if that helps.
The forum software recognizes a url in the middle of a post and makes it a link. If you quote his post, you'll see there are no Here's his link embedded inside the url tags:[url]http://www.amazon.com/Delta-AP400-Shopmaster-Horsepower-Collector/dp/B00006K005/ref=pd_bbs_sr_2/103-5953545-8795014?ie=UTF8&s=hi&qid=1182349494&sr=8-2] tags on it.
