Author Topic: Mechanical rotary joystick interfaces  (Read 1509 times)
sugarlicious
  • Last login:February 25, 2007, 09:07:59 pm
« on: February 25, 2007, 03:22:02 am »
Hello,
Searched the boards and found many outdated links to Druin's rotary interface.
Does someone have a more recent link to Druin's if still up and running?
Or, can someone suggest another interface for rotary joysticks?  I saw the optimarc rotary interface controller.  It is a USB controller; I am guessing I can run mulitple USB interfaces for other input devices along with this and all will be well?
Thanks much
Ninten-doh
  • Last login:March 31, 2017, 10:37:18 am
  • I promise sweetie, this is my last cab purchase
Re: Mechanical rotary joystick interfaces
« Reply #1 on: February 25, 2007, 09:41:45 am »
Rdagger, a member here at BYOAC, built and sold a limited supply of rotary interfaces awhile back.  Works great, but he no longer sells them.  He gives the info on building it yourself on his website: Rototron.info   Go to "projects", and look for "rotary interface".
muzland
  • Last login:May 30, 2011, 06:28:02 am
« Reply #2 on: February 25, 2007, 09:46:02 am »
I am sure that Andy at Ultimarc sells a version of this.
Cheers
Muzland
Ninten-doh
« Reply #3 on: February 25, 2007, 10:20:10 am »
Sure does.  I had just assumed that's what the original poster meant by the "optimarc" interface.   ;D
Anyhoo, here's a link to Andy's interface: http://www.ultimarc.com/rotary.html
I don't think you should have an issue with it interfering with other USB devices.
sugarlicious
« Reply #4 on: February 25, 2007, 09:07:59 pm »
Yep, that is exactly the Ultimarc interface I was asking about.  I will be purchasing one post haste!
Thanks for the help
