Author Topic: Application to switch between MAME & Daphne w/ 1 button press?  (Read 1250 times)
jasonbar
  • Dr. Inferno
    • The Infernolab
« on: February 23, 2007, 07:18:52 pm »
Howdy-
On my MAME cabinet I'm setting up, I'll have essentially MAME & Daphne & almost nothing else.
I've got a SlikStik Quad that I'm upgrading.  It has the I-PAC 4 in it.
I'd like to have a little application that will, upon a certain keypress (preferably one button, perhaps 2 simultaenous keypresses?) quit out of MAME & launch Daphne, or vice versa if pressed again.
Is there some sort of little application swapper or macro program that will map 1 key to do this?
I suppose I could put the MAME & Daphne applications in the Startup folder & then rig up a way to get an Alt-Tab keypress...
Thanks,
-Jason
Re: Application to switch between MAME & Daphne w/ 1 button press?
« Reply #1 on: February 23, 2007, 08:25:49 pm »
Well sure, you can do that but from what I'm understanding you are using the windows guis for those two emus then?  It'd be a lot nicer looking if you'd just use a proper front end.  So long as it supports multiple emulators adding daphne to a front-end's setup should be a no-brainer as it supports command line options and it'll even give you the proper command to use in the daphne loader if you check the box.
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #2 on: February 26, 2007, 07:09:16 pm »
Yes, thanks--I failed to clarify.  I am indeed planning on using MAME32 & Daphne.  As I understand it, to use all my various USB peripherals & such, Windows (XP in my case) is the way to go.  I've got an I-PAC4, Tornado Spinner, Apache push/pull spinner, Happ trackball, keyboard, USB light, 2 ACT light guns, & an analog PC joystick.
I'm only a mechanical engineer--I'm having fun building my control panel & cabinet, but the software & configuration aspects are a challenge to me--which is surely already clear...   :)
Thanks,
-Jason
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« Reply #3 on: February 26, 2007, 10:02:03 pm »
I used Mamewah for this with ease.....
