Author Topic: plumbing question  (Read 3996 times)
sodapopinski
  • Last login:February 12, 2011, 11:13:41 am
  • if I only had normal friends
plumbing question
« on: February 19, 2007, 09:44:30 pm »
I recently roughed in toliet in my mother's basement. I broke away the concrete roughed in the new plumbing and filled the concrete back in. My question is, how do you attach the toliet flange to the concrete floor? I know you just screw it into the subfloor on first and second levels of the house.
Thanks,
PETE
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
Re: plumbing question
« Reply #1 on: February 19, 2007, 10:39:57 pm »
Is "roughed" some fancy Canadian word, or do I just not know anything about plumbing?
Quote from: saint
saint is all powerful.
Apparently he is.
sodapopinski
« Reply #2 on: February 19, 2007, 10:59:43 pm »
Us Canadians are know to use really fancy words. :laugh2:
I know certain terms can differ from Canadaian construction and American construction, but the principals are the same. Platform framing.
we say roughed in, because its simply the abs piping. In new homes the toilet pipe sits out of the concrete in a unfinished basement, its been "roughed in"
« Last Edit: February 19, 2007, 11:32:59 pm by sodapopinski »
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:January 29, 2026, 09:41:01 am
« Reply #3 on: February 19, 2007, 11:28:01 pm »
Roughed in is an American term too used in the same context :)
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
sodapopinski
« Reply #4 on: February 19, 2007, 11:32:32 pm »
I figured that. hear that horseboy?
horseboy
« Reply #5 on: February 19, 2007, 11:35:52 pm »
Well I asked if it was a fancy word or I don't know anything about plumbing. I guess I should have just started off by saying that I don't know anything about plumbing. Still sounds pretty fancy.  :cheers:
Quote from: saint
Apparently he is.
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #6 on: February 20, 2007, 01:30:55 am »
Isn't rough, by definition, practically the opposite of fancy?   ;)
Best Kid iPad Apps
horseboy
« Reply #7 on: February 20, 2007, 01:35:37 am »
Oh, I see how it is.
definition....practically.....of.........now we are geting fancy.
Quote from: saint
Apparently he is.
sodapopinski
« Reply #8 on: February 20, 2007, 01:38:25 am »
I couldn't agree with you more. Still, nobody has the answer to my original question.
boykster
  • The cake is a lie!
« Reply #9 on: February 20, 2007, 01:42:13 am »
Construction adhesive and concrete screws/bolts.  You'll need a concrete bit to drill holes for concrete screws, or to attach the concrete anchors for the expansion bolts, and a good corded drill.
sodapopinski
« Reply #10 on: February 20, 2007, 01:55:03 am »
Yeah I have all that, mabey PL400? I didn't think expansion bolts where used on a toilet flange.
owenowen
  • Last login:August 04, 2007, 04:15:59 am
« Reply #11 on: February 20, 2007, 04:40:00 am »
im a plumber, dont understand your terms though. roughed in is what is said but by toilet flange do you mean pan cone? post photos?
« Reply #12 on: February 20, 2007, 10:37:28 am »
Quiet, fancy boy.
shardian
  • Trade Count: (+23)
« Reply #13 on: February 20, 2007, 10:52:35 am »
He means this:
boykster
« Reply #14 on: February 20, 2007, 02:33:40 pm »
yeah, don't know the name, but I figured it was the flange ring that the anchor posts that mount the toilet attach to.  In my basement, they just used construction adhesive to attach the ring, and then caulked the inside edge (as in the above pic).
I would probably go the extra step and use concrete screws in addition (where the screws are in the above pic)
« Reply #15 on: February 20, 2007, 02:37:21 pm »
So that's a fancy caulk ring?
boykster
« Reply #16 on: February 20, 2007, 02:41:39 pm »
its a flange ring that does 2 things:
- It provides the physical base for the toilet gasket (wax ring) to sit on and mate to the drain pipe
- It holds the flange bolts that hold the toilet in place
« Reply #17 on: February 20, 2007, 02:50:38 pm »
It's a caulk ring that is for sitting on while mating.
shardian
« Reply #18 on: February 20, 2007, 04:07:10 pm »
for the record, I just snagged the first pic from yahoo of a flange I found. I have no clue why they soldered the crap out of the side of the pipe.
The wax ring serves as the sealing device for a toilet connection.
boykster
« Reply #19 on: February 20, 2007, 04:40:22 pm »
chad's just trying to make a funny......
« Reply #20 on: February 20, 2007, 04:49:11 pm »
I do think it's funny that he can't explain the drippy looking substance all over his caulk ring.
