Author Topic: Freedowrapper Application Error  (Read 1176 times)
scottb99
  • Last login:February 21, 2022, 04:41:08 pm
  • Wanting to build my own arcade cabinet!
    • Crown Royal Arcade Machine
« on: February 15, 2007, 09:17:42 pm »
Trying to setup Freedo to work with Mamewah using the Freedowrapper. I'm using JCrouse's ini file example. I keep getting an application error and freedowrapper does not run. "The application failed to initialize properly(0xc0000135). Click OK to terminate the application." Any help would be greatly appreciated.
scottb99
Re: Freedowrapper Application Error
« Reply #1 on: February 15, 2007, 09:20:29 pm »
Nevermind, shortly after my post I found the solution. Needed to install .Net
