Author Topic: Free Software to batch convert WMA to MP3  (Read 3894 times)
muzland
  • Last login:May 30, 2011, 06:28:02 am
« on: February 12, 2007, 04:40:10 pm »
Hi,
Can anyone recommend a good piece of free software for the above?
I have googled but everything I find is limited in some way or will not handle the files I have.
Cheers
Muzland
Space Fractal
  • Space Fractal
    • Space Fractal
Re: Free Software to batch convert WMA to MP3
« Reply #1 on: February 12, 2007, 06:20:25 pm »
You would so get a worser sound quality, since you need to uncompress and then compress again. So never good to convert to other formats (only you "only" would use with small devices).
You cab use Winamp to convert them to all wav files (using discwriter as plugin), and then use cdex to compress them again to a other format. Im known this is not the best option, but it work. Both of them should support subfolders as well.
But you should stick to that format, you originally compressed to. If you have them on cd's, it better to rerip.
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
« Reply #2 on: February 13, 2007, 10:31:34 am »
I'm not sure about free, but dbpoweramp is definitely worth the little bit of money it costs and it does the job fine without quality compromise.
GadgetGeek
  • Last login:July 09, 2024, 09:32:57 am
  • whatever
« Reply #3 on: February 15, 2007, 12:56:01 pm »
foobar2000?
muzland
« Reply #4 on: February 15, 2007, 06:52:09 pm »
Cheers for the suggestions guys,
Foobar2000 is the dogs!
Muzland
