Author Topic: Gameex load fails  (Read 1269 times)
govee
  • Last login:February 19, 2012, 09:26:30 pm
Gameex load fails
« on: February 10, 2007, 01:23:10 pm »
I down loaded and installed all the files on the download page went through the basic setup and gameex fails to load. This is the txt I get.
Win98se, mame061 with a screaming PIII 600EB and 512M ram.
13:13:44.5  2/10/07:  GameEx: Version 7.58: Starting Log
13:13:44.5  2/10/07:  Operating System Platform: Win32Windows
13:13:44.5  2/10/07:  Operating System Name: Windows 98
13:13:44.5  2/10/07:  Operating System Version: 4.10.67766446
13:13:44.6  2/10/07:  Checking for versions of .net Framework installed
13:13:44.6  2/10/07:  .net Framework 1.1 Installed
13:13:44.6  2/10/07:  .net Framework 2.0 Installed
13:13:44.7  2/10/07:  x86 Family 6 Model 8 Stepping 3
13:13:44.9  2/10/07:  Running Randomize()
13:13:44.9  2/10/07:  Loading PlugIns
13:13:45.0  2/10/07:  Checking for applications to Launch On Startup
13:13:45.0  2/10/07:  Initialising Video/MNG DLL's
13:13:45.0  2/10/07:  Running Misc startup tasks
13:13:45.0  2/10/07:  Setting Menu types
13:13:45.0  2/10/07:  Opening Configuration File
13:13:45.0  2/10/07:  Getting Configuration Values
13:13:45.0  2/10/07:  Using Theme: Default - Galaxian
13:13:45.0  2/10/07:  Checking for alternate Image Directory for Theme: Default - Galaxian
13:13:45.1  2/10/07:  Launching HideOS.exe
13:13:45.1  2/10/07:  Hiding Taskbar
13:13:45.1  2/10/07:  Is Media Center running?
13:13:45.1  2/10/07:  Checking/Creating LCD Registry values
13:13:45.1  2/10/07:  Check Media Center Exit/Start Mode
13:13:45.1  2/10/07:  Media Center Mode 2
13:13:45.6  2/10/07:  Snap Delay set to: 2
13:13:45.6  2/10/07:  Get other settings
13:13:46.0  2/10/07:  Set: Find emulator artwork on best match basis
13:13:46.2  2/10/07:  Start work for Form
13:13:46.2  2/10/07:  Getting Original Screen Size
13:13:46.3  2/10/07:  Initializing Component
13:13:46.9  2/10/07:  Initialising Windows Media Player Component
13:13:47.0  2/10/07:  MAME Path is: C:\emulators\mame
13:13:47.1  2/10/07:  MAME EXE file is: mame.exe
13:13:47.1  2/10/07:  ROM Path is: C:\emulators\mame\roms
13:13:47.1  2/10/07:  Catver.ini is located at: C:\PROGRAM FILES\GAMEEX\DATA\catver.ini
13:13:47.1  2/10/07:  controls.ini is located at: C:\PROGRAM FILES\GAMEEX\data\controls.ini
13:13:47.1  2/10/07:  History.dat is located at: C:\PROGRAM FILES\GAMEEX\DATA\history.dat
13:13:47.1  2/10/07:  nplayers.ini is located at: C:\PROGRAM FILES\GAMEEX\DATA\nplayers.ini
13:13:47.1  2/10/07:  MAMEinfo.dat is located at: C:\PROGRAM FILES\GAMEEX\DATA\mameinfo.dat
13:13:47.3  2/10/07:  Loading Controls.ini map file
13:13:47.3  2/10/07:  Snap Path is: C:\emulators\mame\snap
13:13:47.3  2/10/07:  AVI Snap Path is: C:\emulators\mame\snap
13:13:47.3  2/10/07:  Flyer Path is: C:\emulators\mame\snap
13:13:47.3  2/10/07:  Cabinet Path is: C:\emulators\mame\snap
13:13:47.3  2/10/07:  Title Path is: C:\emulators\mame\snap
13:13:47.3  2/10/07:  Panel Path is: C:\emulators\mame\snap
13:13:47.3  2/10/07:  Manual Path: Not Found
13:13:47.3  2/10/07:  Icon Path is: C:\emulators\mame\snap
13:13:47.3  2/10/07:  Marquee Path is: C:\emulators\mame\snap
13:13:47.5  2/10/07:  Loading Custom Emulators
13:13:48.4  2/10/07:  Using 2D Animations
13:13:48.5  2/10/07:  Using General Font: HandelGothic BT
13:13:48.5  2/10/07:  Using Title Font: HandelGothic BT
13:13:48.5  2/10/07:  Initialising DirectDraw
13:13:48.8  2/10/07:  Creating DirectDraw Device
13:13:48.8  2/10/07:  Using Device: NVIDIA GeForce4 MX 4000
13:13:49.0  2/10/07:  Setting Resolution to 800x600 32 bit color
13:13:49.0  2/10/07:  Creating DirectDraw Surfaces
13:13:49.0  2/10/07:  Creating Primary Surface - Full Screen Mode
13:13:49.1  2/10/07:  Creating Back Buffer
13:13:49.2  2/10/07:  Loading graphic Surfaces
13:13:49.4  2/10/07:  Creating Surfaces Misc and Dialogs
13:13:49.7  2/10/07:  Creating Surfaces Volume
13:13:49.7  2/10/07:  Creating Surfaces Arrows
13:13:49.7  2/10/07:  Creating Surfaces GameEXlogo Text
13:13:49.7  2/10/07:  Creating Surfaces Toolbar
13:13:49.9  2/10/07:  Creating Surfaces Backgrounds
13:13:50.0  2/10/07:  Error: 5 - Value does not fall within the expected range.
13:13:51.9  2/10/07:  ERRORS DETECTED: EXITING
PileDriver
  • Last login:May 28, 2025, 08:53:44 am
  • I want to built my own arcade!
Re: Gameex load fails
« Reply #1 on: February 10, 2007, 05:49:59 pm »
You might want to post this at the GameEx Forum.
http://www.gameex.info/forums/
They might be more help
