Author Topic: how to use Mala with mame 69  (Read 3580 times)
govee
  • Last login:February 19, 2012, 09:26:30 pm
« on: February 09, 2007, 11:54:02 pm »
I found a link which describes the need for the mame.xml to be able to use Mala with pre 84 mame and I found instructions at this link (http://209.85.165.104/search?q=cache:F2Fnsm8xT0sJ:www.c3images.com/jukebox/JukeboxInstructions.pdf+mame+xml+file&hl=en&ct=clnk&cd=13&gl=us) to create the file. I created it and changed the name to mame.xml and put it in the mame dir, still no joy. I know I saw a thread that said someone was able to do it. Any one know how to get this done? I get this error.
Error: Object Class: TfrmMenu, Object Function: GpKeyboardHook1KeyAction, Exception Class: EListError, Exception Message: Der Index der Liste überschreitet das Maximum (0)
I am running a pIII 600 win98SE hence the older version of mame.
Andy
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: how to use Mala with mame 69
« Reply #1 on: February 10, 2007, 12:20:41 am »
I use mame .79 with mala
To do it I think I generated a XML with mame .89
If you have no joy with that then....
I guess I can e-mail you my xml file ..... if you PM me your e-mail
Load
govee
Re: how to use Mala with mame 69 ..We have lift off!
« Reply #2 on: February 11, 2007, 08:25:18 am »
Thanks to Loadmans directions I was successful in using Mala with Mae 061. I posted the version wrong in the title. I downloaded 089 loaded my roms and samples. I then created the MAME.ZML file. The XML file was moved to my 061 folder and opened MALA refreshed the main list and 3000 plus games are there.
Thanks Loadman
Andy
