Author Topic: Mounting the Keywiz Max 1.5  (Read 1335 times)
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
« on: February 08, 2007, 05:26:10 pm »
Hey guys Randy sent me the mounting feet and screws for my Keywiz Max 1.5.  My question is this though.  Do I make the screw holes first.  Then lay the feet over the holes, then the board, then screw through the holes of the board into the feet?
Also do you guys put your encoder on the underside of the CP top?  Or do you put it on the inside of the control panel box?
emerica
  • Last login:September 18, 2024, 09:27:07 pm
  • Goodtimes!
    • My ongoing projects
Re: Mounting the Keywiz Max 1.5
« Reply #1 on: February 08, 2007, 09:21:50 pm »
I put my keywiz on the underside of the cp top. Seemed like the logcal thing to do since putting it there would allow you to remove the cp top without the hassle of wires. Just unplug the ps/2 cable and go.
I saw the best minds of my generation destroyed by madness, starving hysterical.
  • Last login:Yesterday at 10:59:21 pm
« Reply #2 on: February 08, 2007, 10:02:01 pm »
Dowdy.... update your project announcement! I swear I'm going to lose $20. I was betting you either wouldn't complete your cabinet or you would die in the process.  ;)
rdowdy95
  • This is my rifle.
« Reply #3 on: February 09, 2007, 10:33:51 am »
Leapin I will.  Man I know my updates suck.  I will take some pics of the control panel top tonight.  I am cutting holes in it with my slow Forstner bit.  I have all of my P2 controls cut out, and I have a sloppy looking trackball cutout, but it will work fine.  It is taking me a while, because I am always watching the youngster.  It will be finished in March sometime.  Need to order a little bit more T-molding then that is the last thing I need.  I have everything else.
Tell me though did you use the little mouting feet.  those are hard to stay still.  Hey but did you mount the keywiz, then wire it up or did you wire it up then mount the keywiz?
« Reply #4 on: February 09, 2007, 10:54:44 am »
mount then wire, and I used the feet on a few of mine and the others I screwed straight to the wood.
    • GroovyGameGear.com
« Reply #5 on: February 09, 2007, 11:20:16 am »
Let me see if I can help.
Probably the best way is to use the KeyWiz board as a template to mark where the holes will go.  Then set the board safely aside and use a very small drill bit (half the diameter of the screws) to make pilot holes.  You can also just pre-screw the screws into the wood and back them out again. However, depending on the material, this may create a hump around the hole that might make it more difficult to keep the standoff in place.
Now, you can use anything mildly sticky to put around your pilot holes.  It just has to hold the standoffs in place for a second while you position the board onto them.  Then just screw the screws in through the KeyWiz board and you're done!
rdowdy95
  • This is my rifle.
« Reply #6 on: February 09, 2007, 12:02:09 pm »
Thanks Leapin Thanks Randy.  You guys are always so helpful.  Leapin Also don't worry man I am working on my Arcade pretty much every other day.  I am trying to also do some things on the PC side.  I need to get a good HOD2 ahk script (for one button esc access), and still need to set Daphne to work in mamewah plus need to get screenshots of some of my PC games and American Laser Games.
