Author Topic: Newbie Question - Dismantling Happ Competition  (Read 1427 times)
thennomeking
  • Last login:August 14, 2014, 03:12:31 pm
  • YIPYIPYIPYIP
« on: February 06, 2007, 04:16:19 pm »
So yes this is a complete newbie question, but for the life of me I cannot figure out how to do it.  Ive never dealt with taking one of these sticks apart.  More specifically how does one remove the bat handle?
And if the answer is simply pull on it, Im going to look like an idiot...
KenToad
  • Last login:Today at 12:16:22 am
  • Flap Flap Flap
Re: Newbie Question - Dismantling Happ Competition
« Reply #1 on: February 06, 2007, 04:22:42 pm »
remove the c-clamp at the base of the handle and the stick will fall right out.  Use a small but solid flathead screwdriver if the c-clamp is particularly resistant.  Just remember only push it to the side.  I usually get the flathead in one of the spaces and twist until it comes partially off, then remove it with my fingers so it doesn't get lost on the floor.
Good luck.
thennomeking
  • YIPYIPYIPYIP
« Reply #2 on: February 06, 2007, 05:09:31 pm »
Thank you KenToad.  Atleast it was alittle more than what I tried, Now I only feel like a partial idiot.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #3 on: February 06, 2007, 05:49:16 pm »
WAIT ... use a pair of needlenose pliers to remove the e-clip ... unless you crave looking on the floor for the clip afterwards ...
Cheers
« Last Edit: February 06, 2007, 05:56:46 pm by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
