Author Topic: Is it possible to do this with MALA?  (Read 7136 times)
CyrusMzRG
  • Last login:July 14, 2019, 07:01:50 pm
« on: February 06, 2007, 10:31:11 am »
Hi folks, I decided create several WAV's which says for example... " Mame GAMES" "Snes GAMES". I would like to know if there is any way for each time I select any mala layout  it plays automatically  that wav. Each wav for its layout...
MAME Games------- for mame layout
Snes Games--------for snes layout
thank you
Cyrus
« Last Edit: February 07, 2007, 02:19:25 pm by CyrusMzRG »
CyrusMzRG
Re: Is possible do this with MALA?
« Reply #1 on: February 06, 2007, 04:57:53 pm »
anybody??
only... auto launch a wav file when I change the emu,
loadman
    • MaLa
« Reply #2 on: February 06, 2007, 06:25:15 pm »
anybody??
Yes...  with a plugin written.   ;) You could ask someone to write it for you I guess. Pretty straight forward.
Without a plug-in you can have MaLa play a way when you change lists. But not a diffent one
CyrusMzRG
« Reply #3 on: February 07, 2007, 09:25:19 am »
Thank you loadman, I hope anybody who reads this post, can help me with this plug-in
Cyrus
loadman
    • MaLa
« Reply #4 on: February 07, 2007, 08:13:03 pm »
Cyrus
OK  ;)
Try this:
http://mala.arcadezentrum.com/plugins.html#EmuWave
This plug-in will play a wave when a emulator is selected.
usage:
1) put the emuwave.mplugin file in the mala\plugins folder
2) copy the wavs you need into the mala\plugins folder
3) run mala
4) enjoy
Note:
This will only work if:
1) The wav has the EXACT name as the emu as displayed on the MaLa layout (case sensitive).
2) The wav files are found in the mala/plugin folder
Enjoy
Loadman
« Last Edit: February 09, 2007, 11:10:43 pm by loadman »
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
Re: Is it possible to do this with MALA?
« Reply #5 on: February 07, 2007, 09:27:10 pm »
loadman - you plugin maniac!   :applaud:
loadman
    • MaLa
« Reply #6 on: February 07, 2007, 09:39:33 pm »
What can I say.. I take-on the easy Jobs.
I leave the smart work for the rest of you  :notworthy:
CyrusMzRG
« Reply #7 on: February 08, 2007, 04:44:51 am »
THANK YOU , loadman, it works perfectly, Now what I need to do is increase the volumen of the wavs because they sound very low with the background music
Thank you again for your help
Cyrus
youki
  • Atomic Front End Creator
    • Atomic Front End
« Reply #8 on: February 08, 2007, 04:58:44 am »
Loadman, you are becoming a Delphi expert!  ;)
loadman
    • MaLa
« Reply #9 on: February 08, 2007, 05:01:49 am »
I don't think so..  :laugh2:  But I have fun doing liittle bits here and there for people
CyrusMzRG
« Reply #10 on: February 08, 2007, 04:34:07 pm »
Hi Loadman, I increased the volumen of the wav till 400% and their sound into mala is still very very low. Are there any way to increase this volumen from your pluging setting it higher than background music??
On the other hand I cannot set the MAME wav with your pluging
thank you
loadman
    • MaLa
« Reply #11 on: February 08, 2007, 05:35:55 pm »
Hi Loadman, I increased the volume of the wav till 400% and their sound into mala is still very very low. Are there any way to increase this volume from your pluging setting it higher than background music??
* I had not used it with BG music..  It is a bit low.  The wavs and the BG music get played via the same volume control. The only option I can think of for you at the moment is put the wav into a Audio Editor a maximise it volume there (not to the point of distortion of course) you may have some room to play with
* As I say in my docs you need to have the wav name the same as the layout is displayed. In the case of mame you change that on the screen attached. Probably best to remove (.) dots too
« Last Edit: February 09, 2007, 11:12:03 pm by loadman »
