Author Topic: Jigsaw settings  (Read 2350 times)
clockwork
  • Last login:December 11, 2008, 11:15:29 pm
  • Time to play!
Jigsaw settings
« on: February 05, 2007, 11:17:24 am »
I have an oscillating jigsaw. It has three levels and can be turned off. It's also variable speed. For cutting MDF, what should I set these at?
Charlie Brown: I'm still hoping that yesterday will get better.
ScottS
  • Last login:November 01, 2007, 02:21:30 pm
Re: Jigsaw settings
« Reply #1 on: February 05, 2007, 03:04:26 pm »
I'd suggest making some cuts in scrap wood and deciding for yourself! In general, as you increase the orbital motion the jigsaw will cut faster but the cuts will be more rough. In theory, the best cut (and slowest) cut quality will be achieved with the orbital motion turned off...
clockwork
  • Time to play!
Re: Jigsaw settings
« Reply #2 on: February 06, 2007, 01:39:48 pm »
Yeah, I'll probably play with it on some test boards. I read something that said there's a difference when you cut harder or softer woods, so I was curious how to determine what the proper settings would be. It's just a matter of cut quality then?
ScottS
Re: Jigsaw settings
« Reply #3 on: February 08, 2007, 02:50:22 pm »
It's a trade-off between speed and quality of cut. With orbital motion off, you get slower speed but better cuts. With orbital on max, you get faster cuts but they may be more rough. For straight-line cutting you may not notice as much of a difference as you would when cutting curves...
