Author Topic: Turbo twist 2 master and slave  (Read 1828 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« on: February 02, 2007, 09:42:28 pm »
What are the benefits of getting a TT2 as a slave?  I already have one and I am looking to get a second so I can play two person driving games.  What would be better another master or a slave?
I b**ch. People listen!!
RandyT
    • GroovyGameGear.com
Re: Turbo twist 2 master and slave
« Reply #1 on: February 03, 2007, 01:34:16 am »
A slave version will hook right up to a TT2 master board as another axis.  The advantage is that it is less expensive.  There are also less wires to run, thus a simpler installation.
RandyT
squirrellydw
« Reply #2 on: February 03, 2007, 11:03:54 am »
So there is no disadvantage to using a slave correct?  Just want to make sure this is no problem using everything in mame, 1 TT2 master, 1 TT2 slave and 1 trackball.  That should work fine right?
RandyT
« Reply #3 on: February 03, 2007, 12:08:35 pm »
How everything behaves will depend on the OS, and version of MAME you are running, but yes.  Those three things will co-exist on a system fine.
RandyT
squirrellydw
« Reply #4 on: February 03, 2007, 01:27:55 pm »
I will be using XP, mame 111 or 112 when that comes out.  Thanks
