Author Topic: Dreamcast and pc idea  (Read 1900 times)
razzerx
  • Last login:December 24, 2020, 10:26:09 am
« on: February 02, 2007, 01:31:44 pm »
I want to hook my Dreamcast and my pc up together in my Mame cab. I was thinking since I'm using an xarcade decoder that I could get the Dreamcast adapter and use a kvm to switch between the two systems. I would use another kvm to switch the video sources. Does this sound like it would work?
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
Re: Dreamcast and pc idea
« Reply #1 on: February 02, 2007, 03:07:37 pm »
Sounds good in theory to me, but why would you need 2 kvm switches.  :dunno
Quote from: saint
saint is all powerful.
Apparently he is.
razzerx
« Reply #2 on: February 02, 2007, 03:12:27 pm »
Because I need to switch video and control panel.
Lilwolf
« Reply #3 on: February 02, 2007, 03:14:47 pm »
they have switches that does both at the same time.
it would be worth it for the extra money if your going to do it.
johnperkins21
  • Last login:December 07, 2019, 07:02:34 pm
« Reply #4 on: February 02, 2007, 03:21:25 pm »
A KVM by definition switches the Keyboard, Video, and Monitor signals to go to one set of Keyboard, Video and Monitor. So you only need one KVM switch. They make them in both PS/2 and USB varieties, although I've had bad luck with some of the USB only devices (especially when running DOS  ;) ).
Bob Dole likes cheese.
razzerx
« Reply #5 on: February 02, 2007, 03:23:31 pm »
I was thinking two because I'll be using the X Arcade Dreamcast adapter wich is serial.
ark_ader
  • I glow in the dark.
« Reply #6 on: February 03, 2007, 12:31:35 pm »
Nope you can get away with a 4 way 9pin serial switch box and a 2 way Vga Box.
I the the same setup but I have the PSX, Xbox ,DC and PC with Laserdisc.  Just make sure you switch to the correct game on the 9 pin switch or you can good up your X Arcade.
I have the Magic VGA which looks pretty cool.  Works a treat, now i need to find the time to play with them all.
KVM would not be the best solution IMO.
Teebor
  • Last login:June 04, 2009, 12:39:06 pm
  • What does this button do??
« Reply #7 on: February 04, 2007, 12:06:24 pm »
Also if you are thinking of using a KVM see if you can see it running before hand.  Some of the makers (like belkin) have problems with higher screen resolutions (or any resolutions on some belkin I have used)
Problems can be blurring or fuzziness of straight lines, flickering picture, or a noticeable drop in quality.
So try another alternative or see if you can demo the KVM you want to use first.
How was your french toast dear?
Smelly and ungrateful
-American Dad
