Author Topic: Some Capcom Fighters are too wide for my TV Display.  (Read 1145 times)
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
« on: January 31, 2007, 01:21:20 pm »
Like Marvel vs Capcom it is like the very left and right portions of the screen are cut off a little bit.  Is this because the resolution of some of those games are a little horizontal/wider?  It's okay if it is, just I lose a little bit of the player 2's picture/chracter icon.
My TV is untampered with as far as resolution settings and service menu settings.  No biggie just wondering if it was like this on some of your mame setups.
ahofle
    • Arcade Ambience Project
Re: Some Capcom Fighters are too wide for my TV Display.
« Reply #1 on: January 31, 2007, 01:25:42 pm »
Try setting the game's resolution to 640x480.
Glaine
  • Last login:April 24, 2013, 12:09:17 pm
« Reply #2 on: January 31, 2007, 01:30:18 pm »
Yep, that usually does it. Might also try playing with Force Aspect Ratio On/Off.
rdowdy95
  • This is my rifle.
« Reply #3 on: January 31, 2007, 01:47:49 pm »
tried the 640x480 thing.  It didn't change I guess my TV just has some overscan on the sides.  No big deal.  I actually no there is some overscan on the sides because in Windows I can't see the scroll bar on windows that are maximized.
ahofle
« Reply #4 on: January 31, 2007, 02:41:58 pm »
Yep, if your windows desktop is 640x480 and you can't see the sides, it sounds like overscan.  Depending on your video card, you can sometimes adjust the TV out geometry in the 'display' control panel (right click on desktop, select 'properties').  ATI drivers allow you to change this anyway.  Otherwise, you'll have to enter your TV's service menu and fix it there.
Loki
  • Last login:August 14, 2012, 08:00:32 am
    • Deathnote
« Reply #5 on: January 31, 2007, 02:42:46 pm »
The resolution for CPS-1 and CPS-2 games is 384 x 224
So it's widescreen.
Don't eat yellow snow.
rdowdy95
  • This is my rifle.
« Reply #6 on: January 31, 2007, 02:57:53 pm »
Yeah that's cool guys.  I am the only one that notices it.  It is a small thing.  Friends are freaking amazed when they come over.  They really like my gun games like All american laser games, and House the Dead 2.
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
« Reply #7 on: January 31, 2007, 08:08:32 pm »
Some of it is the games themselves. They utilize more screen area than most games if I remember correctly. Most of the console ports of the Capcom fighters even had an option in the options screen to play it in its original aspect ratio or squished a bit to fit a home TV.
If you have problems with overscan in general on your TV, you might search the web to see if your TV has a service mode. Most do--you just need to know the right combination of buttons to press on the remote. Obviously you have to be careful what you mess with in the menus, but there should be an adjustment to correct this.
