Author Topic: Any use for a U360 absolute mouse map?  (Read 1657 times)
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« on: January 31, 2007, 08:25:52 am »
As most will know, the UltraStik 360 can be used in "mouse pointer" mode which controls the mouse in the same way as a laptop center-keyboard pointer.
I am playing with a map which will enable the stick to work in absolute mouse mode, where the pointer follows the stick exactly. This will in effect emulate a light-gun but not sure if there is any real application for this. Any thoughts welcome.
Andy
2600
Re: Any use for a U360 absolute mouse map?
« Reply #1 on: January 31, 2007, 08:54:23 am »
Sounds like it would be useful if you think it works and feels ok to you.  It's one of those things where I'd have to try it to see if I can get the right feel out of it for myself, but I'd probably end up using it.
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
« Reply #2 on: January 31, 2007, 08:56:33 am »
I do not own one, but it would be nice to be able to use it to navigate windows for a setup with out a trackball.  If one had a trackball, i dont see a need for that.  as you could use the trackball.
I think it would be a good idea.  if i remember there are a lot of cabs that do not have trackballs, and this would be nice.
destructor
« Reply #3 on: January 31, 2007, 08:59:08 am »
Andy, remember that previous mouse firmware has a bug.
http://forum.arcadecontrols.com/index.php?topic=59092.msg600532#msg600532
AndyWarne
    • Ultimarc
« Reply #4 on: January 31, 2007, 09:30:26 am »
There is no bug as far as I am aware.
After upgrading, the first thing to do is "uninstall" the device in Device Manager and then let it re-detect. This is because the upgrade completely changes the characteristics of the device but leaves its USB ID unchanged. This is not something that would normally happen with a USB device so Windows does get a bit confused.
After that, you need to re-assign the correct joystick number (if not #1) and download a map.
Andy
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
« Reply #5 on: January 31, 2007, 10:17:50 am »
andy - this would be very useful for those without a trackball.  i'm interested. :)
edge
« Reply #6 on: January 31, 2007, 10:18:17 am »
(delete - dup)
edge
« Reply #7 on: January 31, 2007, 10:18:26 am »
(delete - dup)
Aurich
  • Last login:September 12, 2021, 01:34:32 am
« Reply #8 on: January 31, 2007, 12:50:14 pm »
I'd have to use it first of course, but it sounds like it has potential. The more flexible the better, that's the whole strength of the sticks right? :)
destructor
« Reply #9 on: January 31, 2007, 02:37:07 pm »
Andy
What I did:
1. Upgrade firmware to mouse_pointer
2. Restart Windows
3. Run Ultramap and program map
4. Play
If you say that I should uninstall device in Device Manager first I will check it tommorow. But if I first remove device in Device Manager, Ultramap doesn't see U360 and I can't upgrade firmware. Then maybe I should:
2. Remove device in Device Manager
3. Remove U360 from USB
4. Restart Windows
5. Plug in U360 to USB
6. Run Ultramap and program U360
I think it will do nothing but I will check.
PS. With self-press all buttons at one time I have problem on 2 PCs. Kowal's PC is third. You must made chaotic moves using joystick to see how U360 self-press all buttons at one time.
« Last Edit: January 31, 2007, 02:53:17 pm by destructor »
