Author Topic: Mala prevents me from shutting down PC via power button?  (Read 3877 times)
spystyle
« on: January 26, 2007, 09:10:59 pm »
Hello from Maine,
I recently discovered MaLa, it is awesome! Especially for vertical cabs. I set it up in minutes and even made my own skin in a few minutes, what an excellent FE. It also uses very little resources, not much more than mame32.
Anyway - the way I have my cab set up is to power down when I turn the computer off (relay) by pressing the power button the PC. But whe mala is runnign I can't shut down the computer with the power button - only after I exit mala.
I would like mala to close when I shut down the PC, any ideas?
Thank you,
Craig
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: Mala prevents me from shutting down PC via power button?
« Reply #1 on: January 26, 2007, 09:59:14 pm »
How Bizzare.  It works for me
I am using win xp pro (see pic)
alternativley you can have mala shut down the computer when you quit it
spystyle
« Reply #2 on: January 27, 2007, 10:24:45 am »
Thank you,
I did notice that MalA can shut down the PC, but that's with "quitting and confirming" not with a single button press...
So it works for you, huh? That is funky. I am using 98se.
Cheers,
Craig
loadman
  • Moderator
    • MaLa
« Reply #3 on: January 27, 2007, 06:02:24 pm »
Well I have mine set up so if i want to shut down I ....
1) Hit esc (Player 1 + Player 2)
2) Confirm by hitting Player 1
Easy
Yep..I can shut down using 'either' method under XP Pro
