Author Topic: Best way to trim original marquee ?  (Read 1167 times)
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
« on: January 20, 2007, 02:27:24 am »
So I ordered a nos robocop marquee for my cab. I know it will need to be trimmed. What is the best meathod I don't want to screw it up.
ark_ader
  • I glow in the dark.
Re: Best way to trim original marquee ?
« Reply #1 on: January 22, 2007, 07:36:32 am »
Think fold not cut.  I have the same problem.  I have a marquee that is too big.  Yes I could chop it up, but a resale value with folds sounds better.  Take it to a print shop.  They have blades that makes clean cuts.  You might be able to get a copy to fit instead.
Lilwolf
« Reply #2 on: January 22, 2007, 03:19:55 pm »
I bet folding it for any amount of time would also kill the resale value.
but folding is easy and will probably help mounting.
this is assuming that it's not a piece of glass (like my defender marquee).  Then glass cutting is your only option)
rlemmon
« Reply #3 on: January 22, 2007, 09:36:39 pm »
Im not sure if its glass or plexi. It should be gere late this weak.
