Author Topic: can i use cherry microswithches on a magstick plus ?  (Read 1447 times)
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
« on: January 18, 2007, 09:43:08 pm »
I cracked one of the microswitches on my magstick plus   :cry:  The microswitches on it are different than happs. Can I use a cherry switch from  happ as a replacement ?
« Last Edit: January 19, 2007, 02:39:09 pm by rlemmon »
destructor
  • Last login:July 18, 2019, 03:10:07 pm
Re: can i use happs microswithches on a magstick plus ?
« Reply #1 on: January 19, 2007, 12:33:18 pm »
What happ microswitches? :)
Maybe cherry?
http://www.happcontrols.com/joysticks/95073301.htm
Check what microswitchwes you have in MagStik.
rlemmon
« Reply #2 on: January 19, 2007, 02:38:07 pm »
Ya I meant the cherry ones , These ones
http://www.happcontrols.com/joysticks/95073500.htm
This is a quote from there site
"There are three different types of switches used on the Mag-Stick. They all have differing connections. To ensure you use the correct wiring, remove one switch by unscrewing the single fixing screw. On the other side of the switch the connections are marked in the form of a diagram as below:
I'm guessing the cherry snap swithches would do it but I'm not sure, Thanks
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
Re: can i use cherry microswithches on a magstick plus ?
« Reply #3 on: January 19, 2007, 04:49:22 pm »
those switches look exactly the same, except the nc (normally closed) and the no(Normally open) contacts are switched as long as you connect the wire to the no connector you are fine.
