Author Topic: WG 19V2000 cap kit question  (Read 1702 times)
schooie
  • Last login:March 06, 2007, 09:36:24 pm
« on: January 14, 2007, 12:27:31 pm »
I am changing a cap kit for the first time and have a question. The kit and the schematic show caps 500/1/2/3 as 1uf but 2.2uf is installed in the board. 2.2uf have been supplied for c603 and 703 but these have been removed at some point. A 22uf is supplied for c504 but a 47uf has been installed there. The cap kit sizes are correct to the schematic drawings but the installed caps are different. Do I install the caps I have and put the caps 603 & 703 back changing the 47uf back to a 22uf? Or do I locate more 2.2uf and another 47uf cap and install it as is? My original problem was the two slow blow fuses have blown and this is part of my solution.
schooie
Re: WG 19V2000 cap kit question
« Reply #1 on: January 14, 2007, 02:40:41 pm »
I may have my answer on closer inspection I believe I have an Electrohome G05-802 and not a WG 19V2000 as I originally thought.
My bad a newbie mistake maybe.
Does anyone know of anyone who has flyback transformers for one of these available?
D_Zoot
  • Last login:November 18, 2010, 03:59:37 pm
  • Sorry if I get any spit on you...
« Reply #2 on: January 14, 2007, 04:18:32 pm »
I have never seen a failed high voltage transformer on a G05-802. Are you sure you need one?  Failure of this part is rare.
If you do need one, I have never seen a suitable replacement.  Your only hope would be to try and get a good used one, or another complete HV assembly used.
I would ask on the  rec.games.video.arcade.collecting newsgroup, or vectorlist.org
D
