Author Topic: 8 button layout/config  (Read 1990 times)
radiator
  • Last login:April 18, 2013, 07:14:43 pm
  • SFA OK!
    • :: verticalcircle ::
« on: April 02, 2003, 09:28:42 am »
just need some feedback on my layout for 8 buttons...
mame would be setup as follows:
so, you've still got yer capcom 6 button fighter layout, and neogeo games would use 1-4 (1st three fingers on first 3 buttons, and thumb on button 4).
i'm also gonna have my cab setup for console emulation (and have a DC console in there somewhere)
DC layout:
PS layout:
N64 layout:
SNES layout will be same(ish) as the dreamcast layout, but swap A with B and X with Y (L and R stay in the same place)
the N64 layout doesn't have an L button, not sure what to do about that...if a game uses analog control, it's not likely to use the L button as you can't really get to it without moving your hand....but then, if a game uses digital control, it aint gonna use the Z button (for the same reason)...
if anyone has any comments/suggestions, or even uses the same layout, I'd love to hear from you.
cheers
*m
When the Germans bombed the British, the British ducked.
When the British bombed the Germans, the Germans ducked.
When the Americans started bombing, everyone ducked!
Kitbasher
  • Last login:July 23, 2003, 09:25:43 am
    • Kitbasher's Korner
Re:8 button layout/config
« Reply #1 on: April 02, 2003, 10:15:13 am »
THat is exactly the setup I used on my desktop controller.  It works awesome.  I set it up the same way, mainly using the controller for Streetfighter layout and the bottom row for Neo Geo layout.  Works great and easy on the fingers with the curve.  I also play playtstation emulation with a set up just like yours.
Should work great for you.
radiator
  • SFA OK!
« Reply #2 on: April 02, 2003, 11:03:32 am »
cool, well, thats mame + ps sorted (won't bother changing dc either as it's almost same as ps)
just leaves n64, and what to do about the l/r/z buttong thing...
*m
