Author Topic: 49 way joy - cheapest way to interface?  (Read 2323 times)
Texasmame
  • No, no. He's in charge here.
  • Last login:February 18, 2022, 05:28:39 pm
  • Ba, ba, boom!
« on: January 13, 2007, 06:28:35 pm »
Okay, I have a Midway 49 joy.  But with a modular panel, I don't need to have it be an "all purpose" joy, like the GP-WIZ49 can make it.  I just need to have it be a 49 way and that's it.  Sinistar and Food Fight are a must.  Berzerk would also be quite cool with it - kinda like the way it was supposed to be with the opto joy in the first place.  But I digress. . .
I already have an Opti-PAC connected to a rackmount system, interfacing with CAT5 cables (ala Doc's).  I have wired up the following with no issues:  original Pac-Man 4 way stick, Wico 8 way, diaganol mount Coin Controls 4 way, numerous buttons, Tempest spinner and Imperial trac.
So, outside of the GP-WIZ49, what other way is there to interface this joy with MAME?  Mouse hack or something similar and cheap, perhaps?
TIA!
« Last Edit: January 13, 2007, 06:51:24 pm by Texasmame »
NoOne=NBA=
Re: 49 way joy - cheapest way to interface?
« Reply #1 on: January 13, 2007, 08:02:15 pm »
The other two options are an SJC from DaveB, and hooking the joystick directly to your encoder as buttons.
The SJC costs more than the GGG version, and lacks the digital restriction abilities.
Since you don't need the digital restriction, direct connection sounds like it might be what you're looking for.
Texasmame
  • Ba, ba, boom!
« Reply #2 on: January 13, 2007, 08:37:30 pm »
Thanx, but I'm a little confused by this:
Connecting a 49-way Direct Input
Since each pin either has a current or doesn't, they can be treated like buttons. In fact, you can think the williams49 as 6 NC (normally closed) and 2 NO (Normally Open) buttons, and the happs49 as 6 NO and 2 NC buttons. (However, all keyboard encoders and most PC joysticks (to hack) consider a current (closed) as "pressed" and an open circuit as "not pressed"; see next section..)
Thus you can connect a 49-way stick as 8 unused keys or buttons, sending the joystick's output raw to the computer. Official Mame, however, isn't set up to send raw 49-way input directly to a 49-way game. MameAnalog+ adds this feature to the Williams' 49-way games Sinistar, Blaster, Arch Rivals, and Pigskin 621AD (the Atari/Midway 49-way games don't emulate 49-way joystick yet).[/b]
If I'm reading it right, you can use "regular" MAME and the stick will act as if it were 8 buttons - giving you, essentially, an 8 way joy.  But, if you want the "true" 49 way control, you have to go with AnalogMAME.
« Last Edit: January 13, 2007, 08:43:13 pm by Texasmame »
  • Last login:November 30, 2025, 12:59:41 am
« Reply #3 on: January 13, 2007, 08:48:23 pm »
Hi Texasmame. I wanted to do a quick hijack and ask you a question about what you said. Is Berzerk meant to be played with a 49 way? I been playing it with an 8 way and I'm wondering if I'm missing the full experience.
NoOne=NBA=
« Reply #4 on: January 13, 2007, 08:50:32 pm »
Berzerk had an optical 8-way originally, but they were so unreliable that they were almost all replaced.
NoOne=NBA=
« Reply #5 on: January 13, 2007, 08:52:59 pm »
I'm not sure if they ever included the 49-way code into the official version of MAME.
You might shoot urebelscum a PM, and see if it was ever included.
Texasmame
  • Ba, ba, boom!
« Reply #6 on: January 13, 2007, 08:55:17 pm »
Yup.  That's true, not a 49 way but an optical.  My bad.
MYX
  • Last login:September 18, 2020, 05:00:22 pm
  • Even Jesus loves Donkey Kong!
    • MYX Digital Blog
« Reply #7 on: January 13, 2007, 11:40:19 pm »
But, the 49way with DRS would sort of make it a 8 way using optical. So sgood for everyone.
sgoood
BTW, I love my 49 ways and gpwiz49Max(s). Not tellin' you that it is what you need to do, but it works great and you do not need the max to make it work well. You can get the lower end version. The thing is, once you start to play with it and you don't hear clickity click click every time you play, not to mention the feel of a 49 way (very similar to leaf), you may decide to scrap any standard 8 ways anyway.
M    Y    X
BLACKOUT  - Finally rewritten - http://blog.myxdigital.com/
Original BLACKOUT thread - http://forum.arcadecontrols.com/index.php?topic=48239.0
Texasmame
  • Ba, ba, boom!
« Reply #8 on: January 13, 2007, 11:59:05 pm »
sgoood
Ahh, but I got me some of them old fashioned Wico leafs already,so I'm guessing there's not much difference!   ;)
« Last Edit: January 14, 2007, 12:03:51 am by Texasmame »
MYX
    • MYX Digital Blog
« Reply #9 on: January 14, 2007, 01:27:59 am »
sgood ;D
But, DRS. Kaint beat it.
M    Y    X
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #10 on: January 15, 2007, 02:44:33 am »
Half right- if you want to use true 49-way control with this setup, you have to use MAME Analog+.  However, the 8 inputs do not correspond to regular directions, so you won't get jack if you try to hook it up to regular MAME this way- hence no 8-way action.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #11 on: January 16, 2007, 05:19:42 pm »
Yah, that's the current situation. :-[  However....
...You can use a raw 49-way, if you remap the raw 49way inputs to work in mame, but yes mame's default inputs won't work with the raw 49-way input.
You'll have to remap by hand, too, as you won't be able to do the "nots" correctly.  I have old cfg/ini remaps at my site on the 49-way page ("49-way joysticks (raw input) in 4 & 8 way games").  If you don't mind waiting a day or two, I'll update them to the newer cfg/cfg format.  You will still will need to change them to match your setup (eg: to joy7 "buttons" 7-14, instead of the example "j1_pin1-8", if that's what you have it hooked up as).  Note that due to mame's limitations, the 49 different levels, and different people's opinions on best distance moved, I included a bunch of different remap patterns.
Robin
Knowledge is Power
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
« Reply #12 on: January 17, 2007, 12:34:44 am »
KLOV lists it as a 9 way optical.  Is KLOV wrong (wouldn't surprise me)?  Or was it like the wizard of wor 9 way - a 4 way with two levels of up, down, left, and right?
If I do not respond to your post in a timely manner, feel free to PM me.
Kremmit
  • - AHOTW -
« Reply #13 on: January 17, 2007, 02:00:30 am »
KLOV is both right and wrong.
The game only moves in 8 directions, whether you have the original optical stick or not- so it's an 8-way.
-But-
All 8-way sticks are really 9-way sticks:  Four cardinal directions (Up, Down, Left, Right), four diagonals, and DEAD CENTER.  For some reason, with optical sticks like the Berzerk joy and 49-way sticks (48 squares plus dead center!) the center position gets counted, but on regular switched joys, it doesn't.
 :dunno
Texasmame
  • Ba, ba, boom!
« Reply #14 on: January 17, 2007, 03:08:00 pm »
Hey, I got a Midway 49 way joy available now. . .   any takers? ;D
