Author Topic: I'm updating-Questions on Vertical FE  (Read 2248 times)
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« on: January 11, 2007, 04:40:00 pm »
Hello, I'm in the process of updating my FE on a vertical dislay at 640x480.  Which FE's supports rotation WITHOUT doing a hardware rotation through the video board itself.  AdvanceMenu is discontinued, I remember that Mamewah cannot handle this on it's own, does Mala, or GameEX work for rotations (or any other)?
Thanks gang,
Southpaw
loadman
    • MaLa
Re: I'm updating-Questions on Vertical FE
« Reply #1 on: January 11, 2007, 04:46:08 pm »
MaLa and GameEX does as you say.  ;)...  Does not use videocard Hardware
Not sure if GameEX cxan handle 640x480  :dunno
Other FE's can do this too. Have a look at the Wiki here:
http://wiki.arcadecontrols.com/wiki/Front-Ends
If you choose to use MaLa then FYI:
It can rotate when triggered by:
* manually
* by vertical game list
* In cocktail mode when the controller on the side it will flip (if required)
Have Fun  :D
« Last Edit: January 11, 2007, 04:53:10 pm by loadman »
TOK
  • The Game Always Wins
« Reply #2 on: January 11, 2007, 09:34:02 pm »
Its so easy in MaLa. Great front end.
southpaw13
  • Whatever!
« Reply #3 on: January 11, 2007, 09:37:37 pm »
Mala keeps looking better and better :)
Thanks gang,
Southpaw
Havok
« Reply #4 on: January 11, 2007, 11:45:39 pm »
AtomicFE supports auto-rotation based on the game. I'll check with Youki to see, but I believe it is not handled via hardware...
youki
  • Atomic Front End Creator
    • Atomic Front End
« Reply #5 on: January 12, 2007, 03:29:29 am »
Yes, AtomicFE can do that too.
It does not use Hardware.   As all "special" effect in Atomic all is 100% software to be sure it works on all Video Device.
You  can choose to auto-rotate in function of the game or just set the orientation you want at Start.
You can use Rotation in any resolution you want  with any layout you want (including horizontal ones , and what ever the layout resolution is)
southpaw13
  • Whatever!
« Reply #6 on: January 12, 2007, 06:39:02 am »
I will check out Atomic FE too....
Thanks for all the info and hard work on the FE's,
Southpaw
Aurich
  • Last login:September 12, 2021, 01:34:32 am
« Reply #7 on: January 13, 2007, 11:20:50 pm »
I use Mala on my 640x480 vertical setup, but I use iRotate anyways because I want Windows right side up for the odd admin task etc.
Havok
« Reply #8 on: January 14, 2007, 12:05:09 am »
Have you tried playing pc games rotated? I was wondering how well it worked when something requires hardware acceleration...
loadman
    • MaLa
« Reply #9 on: January 14, 2007, 12:41:30 am »
Yeah ....  I'm thinking not good from my experiments
headkaze
  • 0x2b|~0x2b?
« Reply #10 on: January 14, 2007, 01:44:19 am »
I believe iRotate uses hardware rotation, so it should not slow the system down.
loadman
    • MaLa
« Reply #11 on: January 14, 2007, 02:11:02 am »
I found for some mame games it caused a problem .
I have had much more success leaving windows as is and letting mame rotate itself and use a FE that rotates itself
