Author Topic: How is an upright Pac Man Monitor Mounted?  (Read 969 times)
SithMaster
« on: January 10, 2007, 11:43:58 pm »
I checked for the parts needed on mikesarcade and there are two parts that connect together to hold the monitor.  Could someone please post pics of how they all go together.  Thanks.
Mr. Bubblehead
  • Last login:May 16, 2007, 08:49:19 am
  • I use soap.
Re: How is an upright Pac Man Monitor Mounted?
« Reply #1 on: January 11, 2007, 11:44:40 am »
There are two U-channel crossmembers that bolt to the top and bottom of the monitor chassis:
The whole assembly then will slide into the cabinet, and attach to the cab's wooden rails with four small carriage bolts.
Let me know if you need these parts, as I no longer have a use for them.
