Author Topic: Which is the "preferred" trackball method now?  (Read 1724 times)
mtd
  • Last login:December 13, 2003, 04:15:46 pm
  • I want to Build My Own Arcade Controls!!
    • MurderousTreacherousDogs
« on: April 01, 2003, 10:30:11 pm »
Do I get a Happs and optipac or just go with a betson ps2 trackball?  What is the general thought at present?
Jakobud
  • Last login:November 18, 2025, 02:28:46 am
Re:Which is the "preferred" trackball method now?
« Reply #1 on: April 01, 2003, 10:56:57 pm »
Another option is Happs + Hagstrom ME4.  This is what I use and it works very well.
2slk
  • Last login:February 27, 2004, 11:38:09 pm
  • Fascinating, Captain.
« Reply #2 on: April 01, 2003, 11:03:04 pm »
 That really depends on your design. If you have say, swappable panels each with an optical device or two then the optipac would be the way to go IMHO. If you are building a fixed panel that includes one trackball, ps/2 is easy and cheap, so why not?
 As for Betson vs HAPP, there are a few options there too. Betson sells a non-ps/2 trackball as well. Both can be found quite often on Ebay at very decent prices. Hack off the molex connector of the non-ps/2 model and you can hook it up to the opti-pac pretty easily. If you can only get your hands on a ps/2 model and you still want to go the opti-pac route, you can hack it to bypass the ps/2 stuff.
Hope this helps.
seaner
  • Last login:October 21, 2003, 02:10:16 pm
    • http://www.beerbot.ca/mame
« Reply #3 on: April 02, 2003, 01:59:15 pm »
or jsut butcher an oly serial or ps/2 mouse.. everybody has a few of these lying around, don't they??
djsting
  • Last login:July 22, 2015, 08:30:06 pm
    • My MAME Project
« Reply #4 on: April 02, 2003, 04:12:13 pm »
I got a Happs USB trackball which has three buttons that work like the mouse buttons when the unit is just plugged into Windows.  Works great!!
Cue-Ball
  • Last login:August 28, 2006, 07:43:02 pm
  • Discs of Tron > *
    • Grant's Game Grid
« Reply #5 on: April 02, 2003, 05:26:45 pm »
After using a 3" trackball from Happ, i don't think there's any way i could use anything less.  It's got the perfect arcade feel and is rock solid.  I have mine hooked up to an OptiPac and i really can't imagine a cleaner, easier setup.
AX
  • Last login:April 20, 2004, 02:07:53 pm
  • The only way to win is to cheat!
« Reply #6 on: April 02, 2003, 06:36:41 pm »
I agree.  I have the usb happ and it is tight.  Although the price is steep if your on a budget.  There are a few happ balls under control ball on ebay.  prob the best way to go.
Sasquatch!
  • Last login:March 01, 2010, 04:11:47 pm
  • Toot-Toot!
    • Arcade Paradise
« Reply #7 on: April 02, 2003, 07:29:39 pm »
I've never used a Betson, but I did use a PC trackball on my last cab, and I agree with this.  Going to the 3" Happ was trackball bliss.
spidermonkey
  • Last login:October 01, 2023, 04:15:59 am
  • Bombjack junkie
« Reply #8 on: April 02, 2003, 11:25:30 pm »
I have a 3" lighted translucent blue Betson Imperial ps2 version and I have no complaints.  All my controls are on one cp so I don't need to do any hot swapping so ps2 was the right choice for me.
"Sinistar has bad breath"
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #9 on: April 02, 2003, 11:41:37 pm »
I don't have the ps/2 model, but I like both the happs and betson 3" trackballs (attached by optipac).  I lean a little for the happs (longer free spin, louder roll) over the betson, but you should be happy with either.  I started with the very nice kensington expert mouse (2 1/4" ball, one of the better PC trackballs supposedly), but the arcade TBs are way better for gaming.
Robin
Knowledge is Power
