Author Topic: Rotation problem causes MAME to crash  (Read 2042 times)
Funky_K
  • Last login:June 03, 2008, 04:03:20 pm
« on: January 09, 2007, 04:30:45 pm »
I've been having an issue that I can't seem to resolve.  I have an AMD 2600+, 1GB Ram, SiS VGA graphics card, fresh install of WinXP sp2.
I'm using Mame v1.09 with MameWah.  Mame will start the games fine, but will often rotate the screen in the middle of the game and crash back to the desktop, so I end up with a rotated screen... sometimes 90 degree, sometimes 180.
This has also happened while scrolling through different emulators in MameWah.
I have the SiS VGA utility installed which allows me to quickly rotate back and restart MameWah.
Below is my mame.ini... and help would be greatly appreciated.
# <UNADORNED0>            <NULL> (not set)
# CORE PATH AND DIRECTORY OPTIONS
rompath                   roms
samplepath                samples
inipath                   .;ini
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
artpath                   artwork
snapshot_directory        snap
diff_directory            diff
ctrlrpath                 ctrlr
comment_directory         comments
cheat_file                cheat.dat
# CONFIGURATION OPTIONS
readconfig                1
skip_gameinfo             1
# MISC OPTIONS
bios                      default
cheat                     0
# STATE/PLAYBACK OPTIONS
# state                   <NULL> (not set)
autosave                  0
# playback                <NULL> (not set)
# record                  <NULL> (not set)
# mngwrite                <NULL> (not set)
# wavwrite                <NULL> (not set)
# DEBUGGING OPTIONS
log                       1
oslog                     0
verbose                   1
# PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
frames_to_run             0
throttle                  1
sleep                     1
rdtsc                     0
priority                  0
multithreading            0
# VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                1
prescale                  2
effect                    none
pause_brightness          0.65
waitvsync                 0
syncrefresh               0
# VIDEO ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 1
# DIRECT3D-SPECIFIC OPTIONS
d3dversion                9
filter                    1
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# GAME SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
# VECTOR RENDERING OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
# SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
audio_latency             1
# INPUT DEVICE OPTIONS
# ctrlr                   <NULL> (not set)
mouse                     1
joystick                  0
lightgun                  0
dual_lightgun             0
offscreen_reload          0
steadykey                 0
a2d_deadzone              0.3
digital                   none
# AUTOMATIC DEVICE SELECTION OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          mouse
lightgun_device           keyboard
« Last Edit: January 09, 2007, 05:04:49 pm by Funky_K »
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Rotation problem causes MAME to crash
« Reply #1 on: January 10, 2007, 12:57:39 pm »
...This has also happened while scrolling through different emulators in MameWah.
Do you have SiS rotate hotkeys enabled, maybe?
Robin
Knowledge is Power
