Author Topic: modded 360 play regular xbox backups too?  (Read 3699 times)
exibar
  • Last login:January 02, 2025, 11:38:59 pm
  • I'm the creator of Exibar's Lair!
« on: January 07, 2007, 07:57:24 pm »
ok, riddle me this...  If I had a modded 360, would I be able to play the regular xbox backups on the 360 as well as 360 backups?
 thanks!
  Mike b
pointdablame
Re: modded 360 play regular xbox backups too?
« Reply #1 on: January 07, 2007, 09:56:03 pm »
No, not easily.
You can supposedly convert Xbox backups to work with the 360, but you have to use a dual layer disc.  And honestly, I'd say its not worth the hassle.
first off your and idiot
SNAAKE
  • Trade Count: (+29)
« Reply #2 on: January 08, 2007, 12:52:20 am »
samsung drive with latest 5.2 firmware can play single layer xbox1 backups as is(dvd r - and +).
hitachi drive cant play xbox1 backups as is..need to reburn then on dual layer discs.
Hoagie_one
  • Um....whats a cabinet
« Reply #3 on: January 09, 2007, 07:00:57 am »
if you gotta go with the dual layer disks, you might be able to create multidisks and put 2-4 games on one disk.
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:October 08, 2024, 04:40:31 am
  • I am t3h GAY!!!
« Reply #4 on: January 09, 2007, 09:21:00 am »
Nope
It still isn't going to be able to play unsigned code (meaning no custom launch menu), so the only way to have multiple games per disc, would be from ones that are already set up that way.
ie. JSRF/GT2000, Top Spin/NCAA '05, etc... Of course then you have to factor in whether or not they are even on the BC list.
« Last Edit: January 09, 2007, 09:22:49 am by versapak »
SNAAKE
« Reply #5 on: January 09, 2007, 12:06:44 pm »
multi disc of any sort wont work at the moment because xbox360 doesnt really have an iso builder software like xbox1. and like versapak mentioned, 360s cant run unsigned codes yet.
DYNAGOD
  • Last login:May 21, 2012, 07:01:55 am
  • sprites taste better than polygons
« Reply #6 on: January 09, 2007, 01:04:47 pm »
when i place my xbox1 backups (single layer) in my 360 it boots to the xbox1 screen , but a blade comes up on the right side and says an update is needed for the game or will become available in the future.
(hitachi drive)
id say they work
Enjoying the fruits of technological obsolescence one game at a time...
SNAAKE
« Reply #7 on: January 09, 2007, 05:17:18 pm »
try a "supported game" and you will still get the same message ;)
hitachi drive dont play single layer disc.
DYNAGOD
« Reply #8 on: January 09, 2007, 07:16:45 pm »
damn, definetly not worth the hassle of and expense of copying them all to dual layer.. ive still got my xbox1 so ive never really had a reason to try.
thx for the tip though
