Author Topic: onboard GFX  (Read 1186 times)
retourrbx
  • Newbie
  • Last login:January 15, 2007, 05:21:07 pm
onboard GFX
« on: January 04, 2007, 04:08:32 pm »
Hi - Ive just built a cocktail table running Mame...
The CPU is a little weak (celeron 700) so I have decided to buy an AM2 sempron 3000 with an MSI mobo with on board nvidia 6100 GFX chip
What I want to know is whether I will be able to play most games with this or should I upgrade to a PCI card
I am sure that I read somewhere that it is the speed of the processor not the GFX card that dictates what games can be played
If someone could advise and let me know what sort of performance I can expect from this setup Id be grateful
Many thanks in advance
RB
shardian
  • Trade Count: (+23)
Re: onboard GFX
« Reply #1 on: January 04, 2007, 04:10:41 pm »
For the standard MAME collection, you will be good to go. If you start getting into high end CHD's you will start to have problems.
I run a 1.2 Ghz celeron and I can play pretty much everything.
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
Re: onboard GFX
« Reply #2 on: January 04, 2007, 04:54:31 pm »
you should be alright, just keep in mind onboard gfx means that it will be using up some processing power and system ram.  not a tremendous amount.  but just keep that in mind.  Also i am assuming you are connecting it to a pc monitor and not a tv.
