Author Topic: New Avres tool and Ini files  (Read 1524 times)
pacman
  • Last login:October 01, 2007, 09:51:35 am
« on: January 04, 2007, 11:12:38 am »
I have created INI files with the new version of AVRES which is now compatible with latest MAME buids. I am using an horizontal monitor with arcadeVga so I set up AVRES options with Horizontal only, 60hrz and Hardwarestretched but here comes the odd result : for most of my vertical games for which HS is necessary the top and bottom are cut. After a closer look in the INI files of those games I noticed that HS is not enabled by AVRES (HS is on in MAME ini file). Any suggestions? ???
Pacman
