Author Topic: some questions regarding washed out colors/ultimarc video amp  (Read 2065 times)
Cuba
  • Last login:September 20, 2019, 02:29:23 pm
« on: December 30, 2006, 02:38:04 am »
A little while ago I posted regarding my monitor, its kind and whether an avga would work.  Well I know now that it is a standard res monitor.  The chassis is a definitely a Kortek / Sharp Image KTM-F/ KTX series
Ive got the avga hooked up properly, but the picture doesnt look right. The colors look weak.  When I play dvds everything looks kinda grey.  Is this because I need a video amp?
I dunno where to start addressing the problem; is there any way to tell whether this chassis expects 5 volts in?  If I get a video amp and plug it in when it isnt neccessary will I blow something up?
SirPeale
  • Green Mountain Man
Re: some questions regarding washed out colors/ultimarc video amp
« Reply #1 on: December 30, 2006, 02:41:41 am »
If I get a video amp and plug it in when it isn't necessary will I blow something up?
Nope.
Cuba
« Reply #2 on: December 30, 2006, 01:16:02 pm »
Nope.
I just want to be sure I dont damage the monitor.  What would happen if the chassis does indeed want 1 volt and I hook up the vid-amp outputting 5?
SirPeale
« Reply #3 on: December 30, 2006, 02:40:53 pm »
Arcade monitors are expecting 5V.  They may display output with only 1V, but usually it's dim.
Cuba
« Reply #4 on: December 30, 2006, 07:42:42 pm »
Ok, i think I understand now, thanks for info.
