Author Topic: RSS feed?  (Read 6876 times)
RSS feed?
« on: December 29, 2006, 12:25:58 pm »
Don't see one... do we have an RSS feed here?  I'm tempted to slap together an XBMC script to access a couple of arcade related sites (such as here, maybe Retroblast too).
sirwoogie
  • Supreme Chancellor
  • Last login:April 23, 2025, 10:29:35 pm
  • It's Hollyfeld in a Winnebago!
Re: RSS feed?
« Reply #1 on: December 29, 2006, 03:38:18 pm »
Just isn't a link for it. Don't know why they didn't put it in the default themes. I'll be adding an icon for it once we do a custom theme.
Forum: http://forum.arcadecontrols.com/index.php?type=rss;action=.xml
Wiki: http://wiki.arcadecontrols.com/w/index.php?title=Special:Recentchanges&feed=rss
Excerpt from the SMF instructions:
All of the XML content is accessed via the ".xml" action... To get RSS or RSS2 out of that (not viewable in most browsers), add ";type=rss" or ";type=rss2" to that URL.
The default feed is the 5 most recent posts:
http://www.simplemachines.org/community/index.php?action=.xml
There are several "sub-actions" available to this action, specifying exactly what to display:
Recent Posts (displays the most recent posts that you can see)
"Sub-action": recent
Default: Shows 5 most recent posts
Available options:
limit=x - display the "x" most recent posts (if number is less than 5, it will display 5. If number is larger than 255, it will display 255).
board=y - display only the recent posts from board "y"
Example: http://www.simplemachines.org/community/index.php?action=.xml;sa=recent;board=72;limit=10
News (displays the first post from the most recent topics that you can see)
"Sub-action": news
Available options:
limit=x - display only "x" items
board=y - display only news topics from board "y"
Example: http://www.simplemachines.org/community/index.php?action=.xml;sa=news;board=72;limit=10
Members (displays most recent members) - note: There is a bug in the current version of SMF that prevents this from working right - see Latest Members XML Problem for the fix
"Sub-action": members
Available options:
limit=x - display only the "x" most recent members
Example: http://www.simplemachines.org/community/index.php?action=.xml;sa=members;limit=10
Profile (displays the "profile summary" data in a nice XML feed for the specified user)
"Sub-action": profile
Required option:
u=x - display the profile info for user whose ID is "x"
Example: http://www.simplemachines.org/community/index.php?action=.xml;sa=profile;u=150
Now - you're probably wondering what you can do with this. Quite a bit actually.
You can syndicate this stuff by giving people these URLs to use on their sites (they will need to have their own RSS parser to deal with it though - CaRP is a good free one (requires PHP)). You can also use PHP's XML Parser Functions to format the output the way you want it (although you can also do this using SSI.php).
You can also subscribe to these feeds through an XML reader, Firefox, Thunderbird or any other software that supports XML or RSS feeds (note - Outlook and Outlook Express do not support this...) - you will need to have either "type=rss" or "type=rss2" somewhere in the URL for it to work. If you would like to know how to set this up in Firefox or Thunderbird, let me know. Enjoy!
Some other handy ones:
  • The "board" parameter can also take a list by using commas (e.g. board=1,2,3,4) so you don't have to get a listing from everything. Handy for general feeds, but still ignore the ones you don't care about.
The forum can also do WAP output (normally this is autodetected):
http://forum.arcadecontrols.com/index.php?wap
http://forum.arcadecontrols.com/index.php?wap2
http://forum.arcadecontrols.com/index.php?imode
« Last Edit: December 29, 2006, 03:54:35 pm by sirwoogie »
Re: RSS feed?
« Reply #2 on: December 29, 2006, 03:50:20 pm »
Sweet.  I figured there had to at least be a nonconfigured option for it.  No idea if I'll get to it any time soon but I was watching the default XBMC skin scroll what appeard to be an RSS feed from xbox-scene.com and thinking well damn that shouldn't be hard to duplicate for BYOAC.  I don't know Python but I used to make a living as a PERL developer.  Shouldn't be hard to pick Python up.
saint
  • turned to the Dark Side
  • Last login:February 11, 2026, 06:56:49 am
Re: RSS feed?
« Reply #3 on: January 03, 2007, 11:29:17 pm »
Let me know if the text link works please. I set it to the last 20 messages, let me know if that's insane.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
Re: RSS feed?
« Reply #4 on: January 04, 2007, 09:35:59 am »
What do you mean by "the text link"?
I have been poking around in the RSS feed via a Firefox plugin... works well so far, I'm getting the most recent 5 posts.  Not sure if that's a client setting off the top of my head.
saint
Re: RSS feed?
« Reply #5 on: January 04, 2007, 09:54:07 am »
Up above, on the blue menu bar, far right, under the list of forums :)
--- John St.Clair
     Project Arcade 2!
Re: RSS feed?
« Reply #6 on: January 04, 2007, 09:58:16 am »
Found it.  I was able to drag that directly to the RSS client, drop it there, the client recognized it properly and loaded up 20 items.  Seems to work just fine.
saint
Re: RSS feed?
« Reply #7 on: January 04, 2007, 10:24:20 am »
Thanks!  Does 20 seem about right?
--- John St.Clair
     Project Arcade 2!
Re: RSS feed?
« Reply #8 on: January 04, 2007, 10:27:52 am »
I use a lot of RSS feeds and they vary pretty widely.  Given that it creates an item for every post in every thread, 20 seems to be a good place to start.  RSS is better for near-time monitoring than it is for trying to look at the overall picture.
sirwoogie
Re: RSS feed?
« Reply #9 on: January 04, 2007, 12:15:58 pm »
...Given that it creates an item for every post in every thread, 20 seems to be a good place to start.
Remember, you can also use the 'sa=news' function to get links to only the updated "topics."
As for RSS feed links, once we do the update to the forum and consolidate our themes, there will be RSS icons for each board, feed buttons on the main index, and automatic identification to the browsers that support feed discovery.
Re: RSS feed?
« Reply #10 on: January 04, 2007, 01:23:41 pm »
Niiiice.  I didn't know about that.  I popped that on the end of the URL, created a Channel in my RSS client, and it works just as well.  That might be a bit prettier as a GUI scroll on something like XBMC.
EDIT:  well, looks like I don't have to do it!  It's already built in.  I'll give it a shot and report back.
« Last Edit: January 04, 2007, 03:50:55 pm by ChadTower »
