February 15, 2026, 01:59:39 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Main
Monitor/Video Forum
NFL Blitz 99 Arcade blown fuse at power up
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: NFL Blitz 99 Arcade blown fuse at power up (Read 3050 times)
luke4_44875
Trade Count:
0
Newbie
Offline
Last login:December 27, 2006, 01:14:03 pm
on:
December 20, 2006, 07:45:33 pm »
I recently acquired a NFL Blitz 99 arcade that blows the 3 amp fuse on the small transformer where power comes in at as soon as you power it up. If you unplug the monitor everything works fine. I was told that it recently had a cap kit and everything worked fine afterwards.The guy that had it before said it worked perfectly and then it suddenly went out. I think it has a dead short, the fuse blows instantly and is burnt black. Any ideas on where to start?
Logged
tommy
Guest
Trade Count:
0
Re: NFL Blitz 99 Arcade blown fuse at power up
Reply #1 on:
December 20, 2006, 09:17:15 pm »
Lower the power on the power supply?
Logged
Kevin Mullins
Trade Count:
+2
Full Member
Offline
Last login:February 01, 2021, 01:29:34 pm
Reply #2 on:
December 21, 2006, 01:41:54 am »
What make and model monitor is it?
Unplug the degauss coil and see if it still blows.
If it does, then there is more than like a problem in the power supply section of the monitor. (H.O.T., voltage regulator, rectifier diodes, etc)
Logged
castlesteve
Trade Count:
+1
Full Member
Offline
Last login:September 12, 2014, 09:10:32 am
uh, yea
Reply #3 on:
December 21, 2006, 08:12:53 pm »
Im far from a monitor guru.... but it sounds like someone powered their monitor without the isolation transformer. I did this last week... and after that, all it would do is blow the fuse at the transformer from there on out.
i'd say your deflection board is toast.
Logged
grantspain
I personally prefer "bog trotter"
Trade Count:
+1
Full Member
Offline
Last login:August 16, 2025, 04:42:10 am
Reply #4 on:
December 22, 2006, 12:03:57 pm »
its a bit of a strange one,all i can think of is someone has overated the fuse on the monitor chassis and because of a dead short(either degauss circuit or primary power circuit diode)its blowing the fuse on the mains input-check the fuse rating on the monitor first,they are usually about 2 amps
also worth checking whether someone has cut into the monitor power input to provide the marquee lamp with power
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
