February 01, 2026, 11:43:40 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Arcade Stuff
through our link. Thank you!
Main
Monitor/Video Forum
G07 Tube Question
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: G07 Tube Question (Read 1720 times)
FrizzleFried
no one listens to me anyway.
Trade Count:
+4
Full Member
Offline
Last login:November 07, 2025, 04:36:07 pm
G07 Tube Question
on:
December 14, 2006, 01:10:34 am »
OK...I have a 19" Rauland 19VMBP22 tube that has zero burn in. It currently is powered by a PowerMax 1000C chassis which is a re-branded Wei-Ya that is having some geometry issues that a cap kit didn't fix.
I came across a G07 CB0 working monitor with moderate burn-in for $40. I would like to swap out the chassis from the damaged tube to the good tube. Since the good tube was using a chassis that is a "G07 Replacement" it stands to reason that I should be able to do a direct swap without changing the yoke/etc...right?
The good monitor has an ID of 19VBMP22 and the burned monitor has an ID of 19VMJP22.
Last Edit: December 14, 2006, 02:03:49 am by FrizzleFried
Logged
Visit my arcade blog at:
www.idahogaragecade.com
(Updated 10-28-21)
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Last login:October 12, 2021, 12:25:59 am
Technician
Re: G07 Tube Question
Reply #1 on:
December 14, 2006, 02:45:30 am »
The Electrohome yoke connector wiring is different than the connector wiring on the Wei-ya chassis so watch wire color & function lest you damage the chassis.
http://arcarc.xmission.com/PDF%20Monitors/Eygo%20chassis%20Replacement%20for%20G07.pdf
That link will show you the wiring changes on the yoke connector.
Last Edit: December 14, 2006, 02:55:38 am by Ken Layton
Logged
shess
Trade Count:
+6
Full Member
Offline
Last login:January 07, 2021, 04:17:28 pm
Reply #2 on:
December 14, 2006, 06:45:09 am »
If you swap the yokes as well does that eliminate the problem with mismatched hardware?
Logged
FrizzleFried
Trade Count:
+4
Full Member
Offline
Reply #3 on:
December 14, 2006, 09:36:24 am »
My Wei-Ya has a converter that goes from the stock G07 yoke connection to the Wei-Ya connection....if I remove this and plug the old connector in in the correct way, all should be good....
....at least thats what I hope.
Logged
(Updated 10-28-21)
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
G07 Tube Question
