Author Topic: Arcade Renovations sideart (Centipede)  (Read 30417 times)
Justin
  • Last login:January 08, 2026, 10:28:19 pm
    • Centipede MAME cabinet
Re:Arcade Renovations sideart (Centipede)
« Reply #40 on: April 18, 2003, 11:49:31 am »
The priming I've done so far on mi Centipede cabinet has resulted in a slightly texturized surface (which I like, actually, but who cares once its covered by the sideart).
Is this going to pose a problem when I place the sideart sticker?  I'm thinking the side should be as flat as possible for it to adhere properly.  Additional sanding could help, but I've sanded a lot and it still looks texturized (this is the roller's fault.. although I did buy the finest most expensive one)  <shrug>
The other alternative is to keep on priming several layers to get a real thick primed surface and then sand away real hard to smooth it out.  Or should Paint on top of primer and then sand?  Don't know how to make this thing smooth.
ideas?
« Last Edit: April 18, 2003, 11:51:04 am by Justin »
"3 warps to Uranus" -- so I stopped playing!
planetjay
  • Last login:April 22, 2019, 10:50:57 pm
  • Ex-Evil Admin Monkey.
    • planetjay.com
« Reply #41 on: April 18, 2003, 02:05:55 pm »
Hi folks!
What I really wonder - it seems that there is no shape cut?  ???
So shall I cut the outlines of this big worm before I applied it, do I miss something, or is this art supposed to cover the whole side, so I only cut the overstanding edges?
Sorry I didn't see this sooner. On the original, the vinyl went right to the edge. But I think yours looks better! Excelent job on the cabinet!
planetjay.com. Still in Chicago. Still no hurricanes!
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« Reply #42 on: April 19, 2003, 02:18:44 pm »
When I look closely from the side, I've a slightly texture also. You can't feel it though -  it comes from the laminate under the white painting. At least my sideart hasn't peeled off anywhere and I really doubt it will! Of course, hard to tell from here how your surface turned out.
By the way, I updated and redesigned my homepage! Now featuring the sideart-section (how this all was done, lotta pictures) and my new guestbook! (please sign in! Want more english comments there - any other language would be also ok, but I don't understand anything else then english&german ;) )
Justin
« Reply #43 on: April 19, 2003, 02:29:38 pm »
Carlos:
Could you please explain the procedure using water to apply the sideart?  I cannot believe this works... water is like the last thiing I'd want between the sticker and the cabinet...   please explain in detail how this process works!
Carsten Carlos
« Reply #44 on: April 19, 2003, 03:15:30 pm »
Hey Justin,
thanx for signing in!  :D
I updated the attaching-part (much more text) -hope it is clearer now? Just let me know!  :)
Oh, and believe me -water is the thing you would want most between your sticker and your cab at this stage!  ;)
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #45 on: April 19, 2003, 08:58:23 pm »
Carlos:
Ok, the process works like this:
The water allows you to slide around the artwork without it actually sticking. Once you have it positioned how you want it you can squeegee out all the air bubbles to make it perfect. The glue on the sticker is not water soluable so it actually doesn't hurt the sticking power at all. The water evaporates and then you have nothing left but glue which is now firmly attached to your cabinet! (its the same process they use to apply window tint. It works like a charm)
If you build a frankenpanel, chances are I don't care for you as a person.
  • Last login:Today at 12:49:07 am
    • GroovyGameGear.com
« Reply #46 on: April 19, 2003, 09:10:29 pm »
Nice job, Carsten.
I'd just like to comment that water (with a very small amount of mild dish detergent even) is helpful for real, screen printed artwork.  Getting water on unprotected inkjet stuff (kinkos) would be disastrous.
If you intend to use the "wet" application method with inkjet artwork, make sure you get it laminated.  :)
BTW, Carsten, ein Rakel ist ein "squeegee" auf English, und den messer war eine "X-acto" oder "hobby knife"  :)
« Last Edit: April 19, 2003, 09:11:15 pm by RandyT »
Carsten Carlos
« Reply #47 on: April 19, 2003, 09:25:04 pm »
Thanx, RandyT!
Yep, better to include it in my next update. Though I only talked about the screen-printed artwork (you 'll never want anything else when you've seen this quality!) it's better to point that out!
Whee, you are speaking german?  :D Dictionaries are totally lost when you wanna know what a Rakel is!  ;D Now I got some more words I can add tomorrow - now it's time to sleep for me.
I really must add some lines how much better a screen printed sideart looks - of course not an option if you wanna make a sideart of your own.
Nearly forgot this - I did this also, although it doesn't seem a must.
« Last Edit: April 19, 2003, 09:34:51 pm by Carsten Carlos »
Sasquatch!
  • Last login:March 01, 2010, 04:11:47 pm
  • Toot-Toot!
    • Arcade Paradise
« Reply #48 on: April 19, 2003, 10:57:30 pm »
I didn't comment on this before, but GOOD LORD ALMIGHTY that looks so cool!  Great job (and idea), Carsten!
Justin
« Reply #49 on: April 20, 2003, 01:58:47 am »
You mean you can see the texture through the sideart sticker?  or did you mean before applying it?
Carsten Carlos
« Reply #50 on: April 20, 2003, 05:52:55 am »
Thanx, Sasquatch!  :D
Oh god sakes -no, only before!  :o But as I haven't covered the whole cab area, I still can have a look at the uncovered parts of the side.  ;) It is really a VERY slightly texture, it won't shine through any paper. Maybe you have some black laminated furniture at home - I used the same wood for my cab. Its not a woodlike-structure, more like a perls-pattern. (but then, you have to look really closely. I don't think I can photograph this to show you, but I might try)
Updated the sideart-section -thanx RandyT for pointing some missings out!
« Last Edit: April 20, 2003, 06:52:42 am by Carsten Carlos »
Brax
« Reply #51 on: April 20, 2003, 07:09:32 am »
I about forgot this too. A small amount is a drop or two in a spray bottle of water. Give the surface a nice misting, apply your artwork and "rakel" away! hehe
