Author Topic: How do I get +5 Volt power source, I'm a noob in this area, any advice?  (Read 2069 times)
postalp123
  • Last login:March 18, 2024, 09:07:50 pm
  • Retro-gamers don't just play, they reminisce.
Hey guys, need some guidance.
I got a Druin board (Thanks Retro-active!) and in order to wire it up, it requires a 5-volt power source, this is where my ignorance kicks in.
I have an IPac-4 as well as a HAPPs 3" trackball, would either one of these have that Power Supply, or would I have to get it from the PC?
If I have to get the 5-volt from the PC, a few questions:
*What color wire is the 5-volt on the PC's drive connectors?
*Would I need to use the PC's drive connector ground or can I ground the Druin board elswhere (IPac-4??)?
BONUS QUESTION: LOL, sorry, In this review by "Dr. D" http://arcadecontrols.com/arcade_druin.shtml , he mentions that he "adjusted the key speed in Ikari Warriors to get one twist to turn the correct distance", how would I go about adjusting the key speed?
Thanks gents!
-P
« Last Edit: December 11, 2006, 12:16:20 pm by postalp123 »
fatfingers
  • Last login:April 17, 2025, 05:26:08 pm
  • Got UltraStiks?™
Re: How do I get +5 Volt power source, I'm a noob in this area, any advice?
« Reply #1 on: December 11, 2006, 12:38:21 pm »
If your IPAC-4 is already hooked up then it has a +5v input.  You should be able to use that same wire for the +5v for your Druin board.  If you want to use a different wire and need to get it from your computer, the red wire from the driver connectors is 5v.  I believe you can ground whereever you want, but you might want to read other replies about that.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
W.W.P.M.D.?                                       I'm here to help ... I just don't do it. ™
  • Last login:November 30, 2025, 12:59:41 am
« Reply #2 on: December 11, 2006, 12:45:09 pm »
Use a wall wart that has a 5v DC output. Cut off the end and use the 2 wires. Many times, people have tons of them laying around:
postalp123
« Reply #3 on: December 11, 2006, 12:48:01 pm »
Thanks for the reply fatty (and I mean that in the most respectful sense  ;D ) I dont have my IPac-4 sitting here in front of me, but looking at this pic, I cant seem to find the 5 volt lead on it:
If you can locate it on there, let me know, thanks!
Kaytrim
  • I'm too nice a guy
« Reply #4 on: December 11, 2006, 01:00:17 pm »
One thing you will want to get is a multi meter.  You can use it to check the voltages on the power supply of your PC, continuity and other things depending on the complexity of the meter.  For your +5v supply you can use a drive power connector from the PC's power supply.  Here is the pin out of the connector in order.
Yellow     +12v
Black       12v Ground
Black       5v  Ground
Red         +5v
I wouldn't take too much power from a USB power source as they are normally limited to around 300 - 500 milli-amps of power draw, I don't remember the exact limit off hand.  An example of this is Groovy Game Gear's LED-Wiz, there is a limit of the amount of milli-amps you can draw without supplying +5v from an external source.  The drive power source will have plenty of amperage to draw from.
A lot of these simple questions can be answered buy using the forum search.  There is a link on this page and every forum page at the top just above the links to the various boards here.
Sorry I can't help you with your bonus question.
postalp123
« Reply #5 on: December 11, 2006, 01:04:59 pm »
Thanks Kay for the reply,
Funny you mentioned this, because I was actually under the desk with my multimeter between posts and came to the same conclusion (Red = 5 Volts).
Good stuff!
JoyMonkey
  • Voodoo Wiki Master . . .
    • JoyMonkey.com
« Reply #6 on: December 11, 2006, 01:24:09 pm »
The pin header on the IPac has two +5v pins:
http://ultimarc.com/ipac2.html
postalp123
« Reply #7 on: December 11, 2006, 01:35:40 pm »
Thats for an IPAC-2, you think that would matter?
Scumgriever
  • Last login:July 30, 2013, 07:27:31 am
« Reply #8 on: December 11, 2006, 02:17:33 pm »
Yellow     +12v
Black       12v Ground
Black       5v  Ground
Red         +5v
Just as a side note.
This has always thrown me... Whay would they put the lower voltage on the red wire with the higher on the yellow.
I know its been that way for donkeys years but it just seems so counter intuitive. :dunno
fatfingers
  • Got UltraStiks?™
« Reply #9 on: December 11, 2006, 03:21:55 pm »
*sigh*  It seems you are correct and I'm an idiot!  :hissy:  I usually try not to post when I'm not certain, but I thought I was in this case.  It seems the IPAC/4 must get power from the PS2 connector.  I think that means you're back to the drive connector (red).
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
