Author Topic: Did highscore.dat change between v.103 & v.110?  (Read 1987 times)
Dazz
  • HyperSpin Team
    • VPUniverse
« on: December 10, 2006, 10:31:08 am »
Hey Guys,
I've been running MAME v.103 for a long while and just recently went to v.110.  Did something change with the highscore.dat file between those versions?  My old highscore.dat seems to be dropping new scores (on highscore tables), but old highscores still remain.  The latests highscore.dat file that I've seen is v1.05, but my woman would kill me if I lost all of her highscores by replacing my older file. :(  Any suggestions?
FrizzleFried
    • Idaho Garagecade
Re: Did highscore.dat change between v.103 & v.110?
« Reply #1 on: December 10, 2006, 11:37:14 am »
Highscore.dat support was dropped at version .107u1.
It was causing more problems than not so they are now ONLY using SAVESTATES.   Right now only a couple hundred games support savestates...
If you want HIGHSCORE.DAT support,  you MUST go back to version .107....the first beta release after that drops it.
Havok
« Reply #2 on: December 11, 2006, 03:12:15 pm »
Or...
Recompile the current version yourself to include it. MKChamp puts out a diff file to add hiscore support back in. If the last one he posted doesn't work with the current version, he is more than happy to post a newer one:
http://forum.arcadecontrols.com/index.php?topic=60487.msg598304#msg598304
diverdown
  • Last login:April 21, 2025, 03:45:48 am
« Reply #3 on: December 15, 2006, 09:54:03 pm »
I've tried and tried to understand how to recompile mame.
Is there a recompiled 110 version out there already that contains highscore?
If not are there any files that i could copy paste over any in my mame dir?
If it ain't broke give it to me...i'll soon fix that
Havok
« Reply #4 on: December 15, 2006, 10:22:47 pm »
I just compiled 111 with the hiscore diff. Do you have somewhere I can upload it? The dir is around 35MB...
Encryptor
  • Trade Count: (+34)
  • Last login:December 21, 2023, 08:01:18 pm
« Reply #5 on: February 25, 2007, 07:28:10 am »
Ok. I've tried to recompile the current version of mame. It's version .0112b but it just makes mala puke all over itself when I try to run it. I went to Mr Do's website and followed his docs there but to no avail. The one thing his site doesn't really explain is what to do with the hiscore.diff file. Do you patch it like it is an upgrade (ie .0112u1.diff)? Then re-compile?
Could someone post just an outline of the steps in the order they need to be done in.  Any help or docs would be greatly appreciated. Thanks!
Encryptor
