Author Topic: Golden tee trackball won't work.  (Read 1383 times)
ryanborne
  • Last login:April 10, 2007, 03:24:09 pm
« on: December 09, 2006, 11:29:57 am »
Hello, Does anyone know what I have to do to make my trackball work on a golden tee 99 that I am converting from a Strata golden tee 2?  I have the new board plugged in and hooked up the jumper from the board to the trackball.  I also hooked up the -.5 volt wire from my power supply to the correct jamma pin.  I get power to the trackball when I use and eletrical tester, but I get no onscreen response from the trackball.  Is it possible I have a bad PCB?
Drews Arcade
  • Last login:July 28, 2018, 01:15:02 am
Re: Golden tee trackball won't work.
« Reply #1 on: December 09, 2006, 04:18:43 pm »
Is it hooked up to the right trackball connector on the golden tee pcb? Try the other one, these things can be set up in cocktail mode thats when player 2 trackball will work.
ryanborne
« Reply #2 on: December 11, 2006, 06:52:49 pm »
Just got the second board and hooked up two different trackballs and still nothing.  I get power to the trackball but it won't register on screen.  Any ideas?
