Author Topic: WTT Sony Psone LCD  (Read 1056 times)
masamunex
  • Last login:September 01, 2017, 04:00:52 pm
WTT Sony Psone LCD
« on: December 05, 2006, 03:17:23 am »
   Hello everyone, as you can see I'm not much of a poster. I pretty much get all the info I need reading. Ok so I originally planned to use this as apart of a car computer project but decided to just use a laptop instead. The reason I cut the speaker portion out of the front casing due to the space issue regarding my center console. I desoldered the male Multi-AV out because I did not want to cut any wires or solder directly to the lcd pcb for a VGA connection. If your planning on using this as a secondary monitor using a VGA connection then it should be perfect as it is wired up and labeled accordingly. If you can or cant tell from the pictures this lcd has no dead pixels.
   This lcd goes for around $40 used so I am looking to trade for 2 arcade joysticks and 14 buttons. Like something along the lines of this http://cgi.ebay.com/TWO-8-Joysticks-14-Buttons-switch_W0QQitemZ170054296837QQihZ007QQcategoryZ13718QQrdZ1QQcmdZViewItem
If your interested then email me at Masamune1436 at hotmail dot com . Thanks.
