Author Topic: Dummies Guide to A SuperGun???  (Read 3644 times)
WhiteComet
  • Last login:January 13, 2010, 04:22:21 pm
  • iD Project 2010
« on: December 04, 2006, 01:49:57 pm »
Hi guys...
While Im still in the process of building my mame cabinet... Im still thinking of a dedicated arcade machine as a future plan. I can get a few jamma boards but would like to test/play them before its all up and built.
Ive seen these SuperGuns on the net and wonder if theres a guide on building one? Ive seen basic models for £40 but I want a 6 button set up mainlly so I can test the games and boards as the CPS2 have a suicide flaw!!
Has anyone got a dummies guide or even know where I can a guide from?
H T T P : / / W W W . I N I T I A L D O N L I N E . C O M
WhiteComet
  • iD Project 2010
Re: Dummies Guide to A SuperGun???
« Reply #1 on: December 04, 2006, 02:30:04 pm »
I found details... it looks a bit complicated for me.... I might just build the jamma loom into a small box for the time being and use that!!
Is it possible to do that? and how do I get a normal tv to plug into the jamma loom kit?
smythe
  • Last login:June 13, 2010, 04:28:06 pm
« Reply #2 on: December 04, 2006, 03:46:59 pm »
i had a jamma loom that had the end of an rgb scart cable attached to the rgb monitor output...
the r/g/b were connected to the r/g/b but sync ect im unsure  gnd would be to gnd i tink...
a little trail and error and shouldnt be to hard
smythe
« Reply #3 on: December 04, 2006, 03:53:40 pm »
To use a TV you'd have to use one that works with raw RGB.
Q*Bert_OP
  • Oh yes, we did!
« Reply #4 on: December 05, 2006, 05:26:48 pm »
or buy this: eBay Link
I actually bought this color converter board...it works very well, but the picture on the RCA output looks like crap...S-video works well, though...
« Last Edit: December 11, 2006, 07:31:15 am by Peale »
Angry_Radish
  • Last login:October 24, 2020, 06:36:17 pm
« Reply #5 on: December 10, 2006, 03:24:04 pm »
I'm currently building one using the video encoder/decoder chip from a sega saturn, I'll post back when done, but from what other supergun builders said, it's a good price/performance break, outputs composite and svideo
  • Last login:February 05, 2026, 10:50:22 am
« Reply #6 on: December 12, 2006, 02:41:34 pm »
I'd be interested in seeing how this turns out...
Rocky
  • Last login:December 30, 2009, 12:38:41 pm
  • I want to finish my cab before I retire!!
« Reply #7 on: December 15, 2006, 11:37:00 am »
I use a modded PS1 LCD screen.  It is set to accept the same input as an arcade monitor. I just extended the wires to a connector I added at the back of the unit.
« Reply #8 on: December 15, 2006, 11:47:11 am »
I have one of those little converter boards... I agree, composite looks crappy, S Video better.  S Video has a lot less loss in the conversion the little board has to do.
NickG
  • Last login:September 27, 2025, 08:06:19 am
  • Dig.
    • My Projects Page
« Reply #9 on: December 27, 2006, 12:47:13 am »
I bought someones DIY RGB/NTSC converter from ebay for $50 based on a CXA1145P.  I thought I had found a pretty good deal until I opened a $20 Genesis (to mod it the other way around) and found it used an equivalent IC (CXA1145M, IIRC)   :cry:
