Author Topic: What to do????????  (Read 1098 times)
savj14
  • Last login:April 06, 2020, 07:52:46 pm
What to do????????
« on: December 04, 2006, 11:26:01 am »
How can I boot my PC to support an Arcade Monitor?? Or if there is a way to Split the 31Khz Signal like the JPAC does??
I use PowerStrip and Windows XP with my Arcade Monitor and a non ArcadeVGA card. What I do to use my Arcade Monitor and MAME32 in Windows is:
-Boot my PC with my computer Monitor.
-Use PowerStrip to switch to the 640x480i resolution
-Power on my Arcade Monitor and connect the monitor to my PC via Hacked VGA Cable
-Run MALA........Games are using custom Resolutions without Hardware Stretch and fill the screen very nicely
I'd like to do the following if possible(all done without the JPAC or ArcadeVGA):
1. Connect my Arcade Monitor to my PC fully powered on and connect to the Video Card
2. Turn the PC on. Either Divide the Signal, or have some way to protect the monitor from 31Khz
3.Have Windows Start up with the 640x480i Resolution via PowerStrip
Start up MALA front end
I believe I can achieve goal 3. Once the PC is shutdown it should remember to use 640x480 on the next start up. Mala has an option to Start up with Windows. So I just need to find a way to boot my PC with the Arcade Monitor hooked up without ruining it.
I understand this can be achieved using the JPAC and/or the ArcadeVGA, but I'd like to avoid using them. I have already spent many hours of hard work to get this far. I like to do all of the hard work myself and I can look back later and say that it was all worth it.
Any suggestions??
Silver
  • Last login:April 16, 2025, 04:09:53 pm
  • Cunning like the Fox.
    • Mods'n'Mods
Re: What to do????????
« Reply #1 on: December 04, 2006, 11:52:52 am »
I believe it is physically impossible to get the BIOS screens of a PC to boot in a non-31Khz without additional hardware. Likewise with Windows XP, you can't set the default loading screens resolution that I am aware of.
Only options:
1) Jpac/AVGA - you don't want to.
2) build a circuit that will only pass ~15Khz signals, and block 31Khz signals. This would work, not damaging your monitor, but you would see nothing until XP had booted and changed to your 15Khz signal.
3) Ditch XP, and use linux as I believe you can set the framebuffer from boot to be 15Khz (I don't know how, but have read about it). This would leave the bios - but you could investigate LinuxBios project, where you flash you motherboards bios with some linux bootcode. Not easy,straightforward or likely to work IMHO.
4) Probably your best option - add a second VGA card. You can often set which VGA to go first (e.g AGP vs PCI) in your bios. So you could have your arcade monitor hooked up to the second VGA card, which would only kick in once XP had booted and run the drivers. You would be able to set the 2nd VGA card as your primary in XP. Again, you would see nothing on your arcade monitor until XP is booted.
