Author Topic: Emulation now on the Wii!  (Read 5358 times)
barnes
  • Last login:January 10, 2008, 10:15:29 pm
« on: December 03, 2006, 08:54:03 pm »
Ladies and gentlemen, we can emulate on our Wiis now! It uses all the old Gamecube eumlation, but a little tough to set up. REad about it here
Editor Note: Fixed hyperlink
« Last Edit: December 04, 2006, 12:58:43 pm by sirwoogie »
AlanS17
    • AlanS17
Re: Emulation now on the Wii!
« Reply #1 on: December 03, 2006, 09:01:54 pm »
Your link is busted.
pointdablame
« Reply #2 on: December 03, 2006, 09:28:01 pm »
first off your and idiot
AlanS17
    • AlanS17
« Reply #3 on: December 03, 2006, 09:31:17 pm »
fixed link
Thanks. I saw what to do about fixing it, but I was too lazy to do it myself.  ;D
AlanS17
    • AlanS17
« Reply #4 on: December 03, 2006, 09:40:53 pm »
I just finished reading the link. I'm really interested to give this a shot when I got my Wii.
sphetr2
  • Last login:February 08, 2009, 06:35:00 pm
  • black and white album
« Reply #5 on: December 04, 2006, 05:40:36 am »
Of what use is this? With WiiConnect24, bugs like this will be fixed often. Also, they've just found a way to run code on the Wii. They haven't coded anything yet, and that may prove to be more difficult.
pointdablame
« Reply #6 on: December 04, 2006, 08:44:06 am »
There is stuff coded already for the gamecube, and the Wii can run it.
Also, I'm unsure what exactly will run, but if GCOS can be run, there are..... questionable activities.... that may be able to take place with this hack.
As for WiiConnect, if you really want to run this stuff, don't connect.  Simple as that.
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
« Reply #7 on: December 04, 2006, 12:51:41 pm »
Yeah, I expect them to patch this one quick.
That makes me excited about getting a wii going for this though -- how cool is that with no mods?
« Reply #8 on: December 04, 2006, 01:07:00 pm »
Wow.  If you try to run emulators for the GC on the Wii, that's likely running emulators inside an emulator.  We're talking geometrically increased HP needed to run 8-16 bit games.  I know it's REALLY early but now that they have a way to run their own binaries on the Wii you may as well wait for them to port the stuff.  It won't take long.
lloydcom
« Reply #9 on: December 05, 2006, 08:33:58 am »
This is so sad
sphetr2
« Reply #10 on: December 05, 2006, 08:51:33 pm »
This is so sad
What? Please elaborate...
Also, what is the state of the gamecube emulators? They must be pretty crappy (as most owners don't even know you can perform emulation on it, including myself) since the "Gamecube Emulation Scene" not known by many.
Add chad's little performance problem...and what do you get?
3 frames per second!  :lame:
« Reply #11 on: December 06, 2006, 09:07:57 am »
It's a start.  And everything starts someplace.
I bet the GC emulation scene is low because the GC has no hard drive and you'd have to either heavily mod the console or use MiniDVDs AFTER adding the modchip.
  • Last login:July 23, 2025, 07:04:20 pm
« Reply #12 on: December 06, 2006, 05:53:46 pm »
Wasn't someone making custom tops for the GC so you could use full size DVDs?
sphetr2
« Reply #13 on: December 06, 2006, 06:27:49 pm »
Actually, I saw that somewhere online once, and haven't been able to find it since. But the Panasonic Q takes full DVDs, even though it probably has a different architecture than the GC.
« Reply #14 on: December 06, 2006, 07:10:27 pm »
Oh, they're out there and not that hard to find, but they aren't cheap.
pointdablame
« Reply #15 on: December 06, 2006, 08:43:54 pm »
Replacement cases can be had for around $20.  It doesn't really matter much though, since a replacement case does not allow you to store more data on a disc.  The gamecube laser can only read the first 1.4gigs of a disc (the size of mini dvd's), so even a full size DVD case will only allow you to store that amount on a disc.
it's just convenient because a lot of people have blank dvds anyway, and blanks are a bit cheaper than blank mini's
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #16 on: December 07, 2006, 02:46:16 am »
Except god, as it were.
Best Kid iPad Apps
« Reply #17 on: December 08, 2006, 07:54:21 am »
I haven't found any cases less than about $40.  I'll have to keep looking.
A lot of burners won't burn minidiscs and the minidiscs are hard to find locally.  That's why I was never going to back up my games.  I had to tell my kids that they have to ask me to change the games for them, which frankly is a PITA, but at least they haven't wrecked any discs this way.
shmokes
    • Jake Moses
« Reply #18 on: December 08, 2006, 12:44:37 pm »
http://www.modingmaniacs.com/gamecube-c-23.html?osCsid=b01b9d14f882297c90a5dce315d88800
These guys have a replacement case for $17 or $18.  Divineo has the same case for $20.
Best Kid iPad Apps
xxabsentxx
  • Last login:December 21, 2006, 02:54:54 pm
« Reply #19 on: December 21, 2006, 10:10:50 am »
The biggest problem with the full size DVD mod for the GC is 1) you don't gain any extra usage by using bigger disks because the lazer is only going to go to the 1.4 gig point... and 2) using bigger disks tends to put a little extra wear and tear on the motor to spin the disks.  The motors in GCs apparently aren't too great.  You can tweak the lazer to try and help it read better, but once your motor starts getting worn out you'll have a lot of problems.
« Reply #20 on: December 21, 2006, 12:04:48 pm »
Sonofabitch.  $12 for the XenoGC... I just ordered two somewhere else for $24 each.  Finally decided it was time to take the plunge so my kids can swap the discs themselves.
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« Reply #21 on: December 21, 2006, 12:53:34 pm »
Will you also need to modchip to get the GC to boot off the full-size disk?
-pmc
« Reply #22 on: December 21, 2006, 01:00:53 pm »
No, but minidvds are cheap now.  Just have to figure out how to back up the games we have.
pointdablame
« Reply #23 on: December 21, 2006, 01:11:30 pm »
You can do it with the broadband adapter, at least with the Qoob chips.  My guess is it'll be the same for all chips.
« Reply #24 on: December 21, 2006, 01:42:20 pm »
Yeah, the chip I got allows me to back my games up that way but not to stream games to the Cube.  That's fine as I'm not looking to build a library of gamez, just to back up the ones we have so my kids don't trash the discs.
SNAAKE
  • Trade Count: (+29)
  • Last login:October 08, 2025, 05:48:43 pm
  • my joystick is bigger than your joystick !
« Reply #25 on: December 21, 2006, 02:56:15 pm »
whats the deal with wii playing N64 games ?
