Author Topic: monitor se-m21c 25 inch  (Read 2553 times)
peterbe
  • Last login:December 05, 2006, 05:22:52 pm
« on: December 03, 2006, 04:39:43 pm »
some time ago i bought an arcade cabinet to use for Mame, there was still a monitor in it but is  was broke. I found out there was a capacitor and a diode blow up and replaced that. I wanted to check if the monitor was any good and started paying around with advancemame for dos. But until now i wasn't been able to get a real usable image so now i am wondering if the monitor still has problems, i made a wrong cable or it is a advancemame problem. So maybe the first question is if someone has experience with the monitor i have, i have the follwing information about it:
on the board it says  segai se-m21xx , on the schematic i have se-m21c 25 inch and 28 inch (mine is a 25 inch). I found some information on the net about a se-m21xx but it are only 13 and 19 inch.
grantspain
Re: monitor se-m21c 25 inch
« Reply #1 on: December 03, 2006, 05:36:21 pm »
how do you mean usable image,scrambled?
peterbe
« Reply #2 on: December 04, 2006, 03:38:18 pm »
i experimented with the advcfg utility and tried allot of the video modes cga ega vga
and only in ega i got something that looked like the test image of this utility
what i got is an image that is flickering and that is the testimage like 3 or 4 times and overlapping a bit so instead of the one triangle you have top and below i got 3 and not next to each other but overlapping a bit
grantspain
« Reply #3 on: December 04, 2006, 04:31:53 pm »
your monitor is getting the wrong frequency from the pc
peterbe
« Reply #4 on: December 04, 2006, 05:28:53 pm »
yes but what frequency would be wrong the ega? 25 khz if i try cga or vga the picture is even more bad
grantspain
« Reply #5 on: December 04, 2006, 06:04:04 pm »
have you tried your horizontal hold pot?
if you get more than one picture on the same screen the freq is wrong full stop
i guess this is mame,i am not up on mame(fake arcade)stuff but i have seen things about powerstrip in this forum helping with frequency problems
maybe its worth looking at those threads first
i can't find that monitor anywhere how do you know its set on 25khz
grantspain
« Reply #6 on: December 04, 2006, 06:08:48 pm »
yes i can its a happ controls monitor that is 15khz freq,try setting the output at cga and adjust the horizontal hold pot
peterbe
« Reply #7 on: December 05, 2006, 05:22:52 pm »
experimented with the horizontal hold and cga 15 khz got a much better image but i couldn't get it totally steady so i tried extended 16 khz and then the horizontal hold and got a stable picture looks good and tried several resolutions only missing some red colour i think have to look into that
anyway much tanks have been a big help
