Author Topic: The Way Back Time Machine - x2  (Read 5918 times)
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
« on: December 03, 2006, 11:41:09 am »
About a year ago, my friend and I decided to build our own mame systems. My project - Arcade Addiction got off the ground first. Then, last month, my friend decides he's going to build two cabs at once - the second will be a gift for his brother. And oh, by the way, they need to be done for the holiday!
So three weekends ago, we started on the crash build. To speed things up, we decided to cut the side panels out two at a time. This had it's pros and cons - we were done faster and the two sides matched, but the jigsaw blade tended to flex- causing non perpendicular edges. And the effect was enhanced by the thicker wood. We used a belt sander to fix things up.
Router Dust  :dizzy:
My friend's son helped by putting the scraps to good use.  ;D
We worked two long afternoons and made good progress! (The control panel had been completed earlier this summer.)
Work continued the next weekend with a second friend joining the crew. Most of the cabinet is built from 3/4 plywood, but we used MDF for the front and back door panels. MDF dust is not the best thing to inhale - That's me wearing the $1.50 dusk mask and my friend is wearing the industrial strength re-breather!
A slight miscalculation on the monitor shelf height. I must have forgotten to carry the zero.  ::)
Not bad for three days work (about 17 hours).  ;D
Robots will kill you.
Arcade Addiction
GreenKnight37
  • Last login:August 20, 2023, 01:17:16 pm
  • Creating a cab, one Megaman vector at a time
Re: The Way Back Time Machine - x2
« Reply #1 on: December 03, 2006, 04:57:56 pm »
Looking good, especially considering its two cabs and a crunch time frame.
theCoder
« Reply #2 on: December 04, 2006, 11:39:36 am »
Great progress in such a short time.  Now if you can only keep up this pace...  Lookin good.
« Reply #3 on: December 04, 2006, 12:01:55 pm »
I agree.  You guys are making really fast progress.  Next time you are in a rush to build 2 cabs at once (;D), I'd recommend getting a pattern bit for your router.  Cut one piece with the jigsaw, sand it to where you like it and then trace it a bunch of times, cut 1/8" wide of the line freehand and then use the pattern bit to make exact copies...
Keep it up!
arzoo
    • LEDBlinky
« Reply #4 on: December 11, 2006, 08:14:51 am »
Painting has commenced with the primer and first top coat (black) completed over the weekend.
Here are a couple pics after the primer was applied. Check out the grill work for the speakers.
Arcade Addiction
arzoo
    • LEDBlinky
« Reply #5 on: December 11, 2006, 09:58:33 am »
Painted Black!
Arcade Addiction
Kaytrim
  • I'm too nice a guy
« Reply #6 on: December 11, 2006, 10:38:33 am »
Are these cabs going to have different looks or are they going to be cookie cutter copies of each other?
arzoo
    • LEDBlinky
« Reply #7 on: December 11, 2006, 10:44:16 am »
The cabs and cp's are identical, but the graphics and marquee may be different. One of the two will use the Way Back Time Machine theme.
Arcade Addiction
gamenut
  • Last login:January 05, 2010, 06:11:46 pm
« Reply #8 on: December 12, 2006, 01:01:33 am »
wow, good luck guys, I've got two months on my cab so far!  I can't imagine doing two on such a short time frame.
 :notworthy:
You must not have day jobs :laugh2:  J/K
Kaytrim
« Reply #9 on: December 12, 2006, 10:16:05 am »
It is a lot easier and quicker to have help when building something of this size.  Believe me I know.  If I had help on a regular basis I would have completely finished off my basement a year ago instead of only being 1/3 the way through.
arzoo
    • LEDBlinky
« Reply #10 on: December 20, 2006, 08:09:13 am »
Here's a look with the front panel and coin door.
Arcade Addiction
arzoo
    • LEDBlinky
« Reply #11 on: February 01, 2007, 08:00:31 am »
The control panel wiring is complete! Updated pics - graphics on the side and cp.
Arcade Addiction
clockwork
  • Last login:December 11, 2008, 11:15:29 pm
  • Time to play!
« Reply #12 on: February 01, 2007, 07:43:10 pm »
Very nice. I like how the lightning spreads from the trackball. Did you get that sideart from mamemarquees? I was thinking of going with that design, but it seems rather expensive from them.
Charlie Brown: I'm still hoping that yesterday will get better.
arzoo
    • LEDBlinky
« Reply #13 on: February 06, 2007, 08:42:21 am »
Yes, all the artwork came from mamemarquees. The original plan was for custom artwork with a way back time machine theme. But the project needed to be semi-completed by mid February.... so mamemarquees was a good (temporary?) solution.
Arcade Addiction
