Author Topic: ArcadeVGA card & Fresh XP Installation Screen Problem??  (Read 1847 times)
lettuce
  • Make It So!
« on: November 18, 2006, 07:14:14 am »
I am tring to format my C Drive with windows XP and do i fresh install, but for some reason the ArcadeVGA card doesnt seem to display the whole screen when initially setting up windows (the Blue Screen with White Writing setup), it displays the top half of the screen but the bottom half is blacked out completely, and thus i can not see what partition i am making, and which method im using to format the Drive. Has anybody come across this, and if so how do i get the whole screen displayed??
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
Re: ArcadeVGA card & Fresh XP Installation Screen Problem??
« Reply #1 on: November 18, 2006, 06:11:04 pm »
Could be wrong about this, does your version of the arcadeVGA have 2 outputs? Does the other output anything difference?
miles2912
« Reply #2 on: November 18, 2006, 07:27:23 pm »
Without going into too many details your best bet is to use any card you have to do the install and then put in the a-vga card after windows is set up.
D-
diverdown
  • Last login:April 21, 2025, 03:45:48 am
« Reply #3 on: November 18, 2006, 08:10:34 pm »
What miles said
And with regard to Silver
If you are using an Avga2 don't forget to use the DVi out, not the "normal" looking video out - that is only for the arcade monitors.
If it ain't broke give it to me...i'll soon fix that
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #4 on: November 19, 2006, 11:38:54 am »
Using an arcade monitor for the complete Windows setup from cold is not a good idea, as well as this problem mentioned, the install process attempts later on to change the screen to 800 X 600 which is also not good.
So, as has been mentioned, either use another card then swap out after Windows is installed or use a PC monitor via the DVI port if its an AracdeVGA 2 card.
Andy
