Author Topic: Matching balltop for both Happ Super and 49-Way?  (Read 1275 times)
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« on: November 15, 2006, 08:29:07 am »
Does anyone make replacement balltop joystick handles for both a Happ Super and a Midway(Happ?) 49-Way? Ideally, I'd like them to light up, but that seems unlikely. My cp has a bunch of Supers and a single 49. The bat tops are actually very similar, but I'd like to switch to ball tops.
On a similar note, I see that GGG sells a balltop for the newer 49-Way. How do I know which one I have (I purchased it about 10 months ago from eBay)?
Robots will kill you.
Arcade Addiction
RandyT
    • GroovyGameGear.com
Re: Matching balltop for both Happ Super and 49-Way?
« Reply #1 on: November 15, 2006, 01:45:28 pm »
The Versa49 shafts are designed to work with the HAPP 49-way sticks.  The older Midway sticks, often found used on eBay, use a different shaft size, so the Versa49's won't be compatible with those.
If you measure the shaft and find it to be about 1/4", then you have the older ones.
RandyT
arzoo
    • LEDBlinky
« Reply #2 on: December 05, 2006, 11:20:57 am »
Mine is the older Midway 49way  :(
Arcade Addiction
